Bug: SilentOperation is most of the time not silient
JelteDeJong
JelteDeJong
I can produce this problem with a part that has the following 3 ilogic rules.
rule: [main]
Dim iLogicAddin As ApplicationAddIn = Nothing
Dim iLogicAutomation
iLogicAddin = ThisApplication.ApplicationAddIns.ItemById("{3bdd8d79-2179-4b11-8a5a-257b1c0263ac}")
iLogicAutomation = iLogicAddin.Automation
iLogicAutomation.RunRule(ThisDoc.Document, "with-Imports") ' msgbox 1: Does show
iLogicAutomation.RunRule(ThisDoc.Document, "none-Imports") ' msgbox 2: Does show
iLogicAutomation.SilentOperation = True
iLogicAutomation.RunRule(ThisDoc.Document, "with-Imports") ' msgbox 3: Does NOT show
iLogicAutomation.RunRule(ThisDoc.Document, "none-Imports") ' msgbox 4: Does show
iLogicAutomation.SilentOperation = False
iLogicAutomation.RunRule(ThisDoc.Document, "with-Imports") ' msgbox 5: Does show
iLogicAutomation.RunRule(ThisDoc.Document, "none-Imports") ' msgbox 6: Does show
Rule [with-Imports]
AddReference "GDH.Inventor.iLogic.Utilities.dll"
Imports GDH.Inv.iLogic.Utilities
Parameter("TEST") = Parameter("TEST") + 1
MsgBox("Test = " & Parameter("TEST"))
Rule [none-Imports]
' imports System.IO
When i start the rule [main] i get 5  msgbox's. All msgbox's are shown when the iLogic-addin isn't in SilentOperation. But when the iLogic-addin is in SilentOperation then:
  • the rule with the imports-statement does not show a msgbox like i would expect form SilentOperation.
  • the rule without an import-statement does show a msgbox wich i would not expect.
it is a bit more complicated because the import statement should be to the namespace of a dll that is also loaded in the rule. for example the following import statement will not make the msgbox disapear.
imports System.IO
Jelte de Jong
Blog: hjalte.nl - github.com
JelteDeJong
Here is also the part file that i use for testing for any one who wants to see it. But i can not attached the refrenced dll in the forum. (If anyone from autodesk wants it for testing purpose then plz send me a personal message) There for the rules will not work at all.
Jelte de Jong
