Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Bug iLogic rule wrong formatting with "case else"
Pav3L
Pav3L
we are using Autodesk Inventor Professional 2022 and we are hawing problems with automated formatting of iLogic rules when we use "case else" in a rule.
See attached screenshots or the code below. This is just small part of a rule.
Wrong formatting, the "End If" after "End Select" and also the rest of the rule is shifted to the right which makes it very difficult to orient, I think it should be in line with the starting "If".
'LABEL PLATE AUTOMATIC CUSTOMER SELECTION
If LabelPLT_on_automatic = False Then
	Select Case Customer
		Case "NKT COLOGNE", "NEXANS ROGNAN"
			LabelPLT_on = "ONE FLANGE ONLY"
			Parameter("LABELPLT B", "Sketch_TextVisibility") = Customer
		Case "BRUGG CABLES", "HEXATRONIC", "ELCOWIRE"
			LabelPLT_on = "BOTH FLANGES"
		Case Else
	LabelPLT_on = " NONE"
	End Select
	End If
	'LABEL PLATE ON/OFF
	Select Case LabelPLT_on
		Case " NONE"
			Component.IsActive("LABELPLT A") = False
			Component.IsActive("LABELPLT B") = False
			Component.IsActive("RIVET1 A") = False
			Component.IsActive("RIVET2 A") = False
			Component.IsActive("RIVET1 B") = False
			Component.IsActive("RIVET2 B") = False
			LabelPLT_on_switch = False
Correct formatting, "case else" is not used (commented) and the "End if" and rest of the rule is correctly on the left side.
			'		Case Else
			'	LabelPLT_on = " NONE"
	End Select
End If
'LABEL PLATE ON/OFF
	Case " NONE"
Is this a bug or am I doing something wrong? Is there a way how I can fix the formatting?
Thank you
Michael.Navara
I confirm this issue.
I recommend you to use VisualStudio for iLogic rules creation. Is it possible to use my solution  iLogic for VisualStudio or ILogicRuleTester by @JelteDeJong
Pav3L
Ok, so this really loooks like a bug.
Where can I report it, so they can maybe fix it?
