Bug iLogic rule wrong formatting with "case else"
- Mute
- Permalink
- Report
we are using Autodesk Inventor Professional 2022 and we are hawing problems with automated formatting of iLogic rules when we use "case else" in a rule.
See attached screenshots or the code below. This is just small part of a rule.
Wrong formatting, the "End If" after "End Select" and also the rest of the rule is shifted to the right which makes it very difficult to orient, I think it should be in line with the starting "If".
'LABEL PLATE AUTOMATIC CUSTOMER SELECTION
If LabelPLT_on_automatic = False Then
Select Case Customer
Case "NKT COLOGNE", "NEXANS ROGNAN"
LabelPLT_on = "ONE FLANGE ONLY"
Parameter("LABELPLT B", "Sketch_TextVisibility") = Customer
Case "BRUGG CABLES", "HEXATRONIC", "ELCOWIRE"
LabelPLT_on = "BOTH FLANGES"
Case Else
LabelPLT_on = " NONE"
End Select
End If
'LABEL PLATE ON/OFF
Select Case LabelPLT_on
Case " NONE"
Component.IsActive("LABELPLT A") = False
Component.IsActive("LABELPLT B") = False
Component.IsActive("RIVET1 A") = False
Component.IsActive("RIVET2 A") = False
Component.IsActive("RIVET1 B") = False
Component.IsActive("RIVET2 B") = False
LabelPLT_on_switch = False
Correct formatting, "case else" is not used (commented) and the "End if" and rest of the rule is correctly on the left side.
' Case Else
' LabelPLT_on = " NONE"
End Select
End If
'LABEL PLATE ON/OFF
Case " NONE"
Is this a bug or am I doing something wrong? Is there a way how I can fix the formatting?
Thank you
Link copied
