Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Bug iLogic rule wrong formatting with "case else"
2 REPLIES 2
Pav3L
271 Views, 2 Replies
we are using Autodesk Inventor Professional 2022 and we are hawing problems with automated formatting of iLogic rules when we use "case else" in a rule.
See attached screenshots or the code below. This is just small part of a rule.
Wrong formatting, the "End If" after "End Select" and also the rest of the rule is shifted to the right which makes it very difficult to orient, I think it should be in line with the starting "If".
'LABEL PLATE AUTOMATIC CUSTOMER SELECTION
If LabelPLT_on_automatic = False Then
	Select Case Customer
		Case "NKT COLOGNE", "NEXANS ROGNAN"
			LabelPLT_on = "ONE FLANGE ONLY"
			Parameter("LABELPLT B", "Sketch_TextVisibility") = Customer
		Case "BRUGG CABLES", "HEXATRONIC", "ELCOWIRE"
			LabelPLT_on = "BOTH FLANGES"
		Case Else
	LabelPLT_on = " NONE"
	End Select
	End If
	'LABEL PLATE ON/OFF
	Select Case LabelPLT_on
		Case " NONE"
			Component.IsActive("LABELPLT A") = False
			Component.IsActive("LABELPLT B") = False
			Component.IsActive("RIVET1 A") = False
			Component.IsActive("RIVET2 A") = False
			Component.IsActive("RIVET1 B") = False
			Component.IsActive("RIVET2 B") = False
			LabelPLT_on_switch = False
Correct formatting, "case else" is not used (commented) and the "End if" and rest of the rule is correctly on the left side.
			'		Case Else
			'	LabelPLT_on = " NONE"
	End Select
End If
'LABEL PLATE ON/OFF
	Case " NONE"
Is this a bug or am I doing something wrong? Is there a way how I can fix the formatting?
Thank you
2 REPLIES 2
Michael.Navara
in reply to: Pav3L
I confirm this issue.
I recommend you to use VisualStudio for iLogic rules creation. Is it possible to use my solution  iLogic for VisualStudio or ILogicRuleTester by @JelteDeJong
Pav3L
in reply to: Pav3L
Ok, so this really loooks like a bug.
Where can I report it, so they can maybe fix it?
