- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
We have iLogic that uses an Excel file to populate iProperties of Part files. There will be different Excel workbooks for each of our projects. I was wondering if it is possible to put code in that would allow the user to browse to the file location and then that would fill/replace the location within the code. This would allow us to use the same template for all of our projects rather than making project specific templates where the file location has to be changed in the Ilogic. I have included the current code below.
Dim AssyDoc As AssemblyDocument = ThisDoc.Document Dim oAsmCompDef As AssemblyComponentDefinition = AssyDoc.ComponentDefinition Dim oDocFile As Document, oDocFileName As String For Each oOcc As ComponentOccurrence In oAsmCompDef.Occurrences If Not TypeOf oOcc.Definition Is VirtualComponentDefinition Then On Error Resume Next oDocFile = oOcc.Definition.Document oDocFileName = oDocFile.displayname 'Set your delimiter Delimiter = InStr(oDocFileName, "-") Description = Left(oDocFileName, Delimiter - 1) 'Open the Excel file GoExcel.Open("C:\Users\estringer\Documents\Work\Inventor_modeling\iLogic\Unit_Drawing_Tests\Part_iProperties.xlsx", "Parts") 'Look at the first 15 rows of the Excel file 'Start at row 2, since row 1 contains headings For rowCheck = 2 To 15 'Compare the part name to the value in column A If GoExcel.CellValue("A" & rowCheck) = Description Then iProperties.Value(oDocFileName, "Custom", "Extrusion") = GoExcel.CellValue("B" & rowCheck) iProperties.Value(oDocFileName, "Custom", "Alloy-Temper") = GoExcel.CellValue("C" & rowCheck) iProperties.Value(oDocFileName, "Custom", "Material") = GoExcel.CellValue("D" & rowCheck) iProperties.Value(oDocFileName, "Custom", "Finish") = GoExcel.CellValue("E" & rowCheck) iProperties.Value(oDocFileName, "Custom", "Color") = GoExcel.CellValue("F" & rowCheck) iProperties.Value(oDocFileName, "Custom", "Hydro Code") = GoExcel.CellValue("G" & rowCheck) iProperties.Value(oDocFileName, "Custom", "Routing") = GoExcel.CellValue("H" & rowCheck) iProperties.Value(oDocFileName, "Project", "Description") = GoExcel.CellValue("I" & rowCheck) End If Next 'Open the Excel file GoExcel.Open("C:\Users\estringer\Documents\Work\Inventor_modeling\iLogic\Unit_Drawing_Tests\Part_iProperties.xlsx", "Infills") 'Look at the first 15 rows of the Excel file 'Start at row 2, since row 1 contains headings For rowCheck = 2 To 15 'Compare the part name to the value in column A If GoExcel.CellValue("A" & rowCheck) = Description Then iProperties.Value(oDocFileName, "Custom", "Routing") = GoExcel.CellValue("B" & rowCheck) iProperties.Value(oDocFileName, "Project", "Description") = GoExcel.CellValue("C" & rowCheck) iProperties.Value(oDocFileName, "Custom", "Make-up") = GoExcel.CellValue("D" & rowCheck) End If Next End If Next oOcc GoExcel.close
