Box.IsDisjoint Method
fakeru
fakeru
I'm trying to suppress with VBA all occurrences in assembly based on the condition if they intersect a part(cube:1).
I'm using rangeboxes for that and IsDisjoint methond. However nothing works as I expect.
Public Sub CutBox()
Dim AssDoc As AssemblyDocument
 Set AssDoc = ThisApplication.ActiveDocument
        Dim oAsmCompDef As Inventor.AssemblyComponentDefinition
        Set oAsmCompDef = AssDoc.ComponentDefinition
        Dim oOcc As ComponentOccurrence
        Dim CutBox As Box
       Set CutBox = AssDoc.ComponentDefinition.Occurrences.ItemByName("Cube:1").Definition.RangeBox
        For Each oOcc In oAsmCompDef.Occurrences
            If oOcc.Definition.RangeBox.IsDisjoint(CutBox) = True Then
                oOcc.Suppress
            End If
        Next
End Sub
Any idea what's wrong? I'm sure that some occurrences' rangebox do not intersect the cube's part range box, but Inventor doesn't suppress those occurrences.
Regards
Alexandru
Autodesk Inventor 2015 Certified Professional
fakeru
I found the solution myself. I had to delcare and set the rangebox of each occurrence:
Dim oRB As Box
Set oRB = oOcc.RangeBox
So the entire code looks like this:
Public Sub CopySketch()
 Dim AssDoc As Inventor.AssemblyDocument
        Dim CutBox As Box
         Dim oRB As Box
            If oRB.IsDisjoint(CutBox) = True Then
                oOcc.Suppress
            End If
        Next
End Sub
fakeru
Actually that didn't fix the problem.
The code doesn't work in a consisten manner. Occurrences are being suppressed not based on the rangeboxes interference.
Later edit:
Now it seems like I found the problem. It was in this line:
 Changed to
Set CutBox = AssDoc.ComponentDefinition.Occurrences.ItemByName("Cube:1").RangeBox
And it worked
