Thanks for reply rhasell,
i get the following message:
System.ArgumentException: Falscher Parameter. (Ausnahme von HRESULT: 0x80070057 (E_INVALIDARG))
bei System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
bei Inventor.BOMViews.get_Item(Object Index)
bei LmiRuleScript.Main()
bei Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
bei iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
I am a beginner with iLogic.
What i like to do is: To renumber the Position in an structured bom assembly, for example: 1, 2, 4, 7 renumber to 1,2,3,4
Thanks for your help.
Regards
Martin
