BOM EXPORT | EACH ASSEMBLY IN A CSV
tpascual
tpascual
Hi Sirs,
Any idea about how to export BOM, but create a new csv for each assembly in the structure?
Of course via API.
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi tomas,
Please find the following code to export BOM in csv
    Dim oDoc As AssemblyDocument
    Set oDoc = ThisApplication.ActiveDocument
    ' Set a reference to the BOM
    Dim oBOM As BOM
    Set oBOM = oDoc.ComponentDefinition.BOM
    ' Set the structured view to 'all levels'
    oBOM.StructuredViewFirstLevelOnly = False
    ' Make sure that the structured view is enabled.
    oBOM.StructuredViewEnabled = True
    ' Set a reference to the "Structured" BOMView
    Dim oStructuredBOMView As BOMView
    Set oStructuredBOMView = oBOM.BOMViews.Item("Structured")
    ' Export the BOM view to an Excel file
    oStructuredBOMView.Export "C:\Temp\StructuredBOM.csv", kTextFileCommaDelimitedFormat
Please free to contact if there is any doubt.
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
MechMachineMan
vb.net (to use as a rule):
Sub Main()
Dim oDoc As Document
For Each oSubDoc in oDoc.AllReferencedDocuments
If oSubDoc.DocumentType = kAssemblyDocumentObject Then
Call ExportDocStructBOM(oSubDoc)
End if
Next
MsgBox("Rule Complete!")
End Sub
Sub ExportDocStructBOM(oDoc As Document)
Dim oBOM As BOM oBOM = oDoc.ComponentDefinition.BOM oBOM.StructuredViewFirstLevelOnly = False oBOM.StructuredViewEnabled = True Dim oStructuredBOMView As BOMView oStructuredBOMView = oBOM.BOMViews.Item("Structured") oStructuredBOMView.Export("C:\Temp\StructuredBOM.csv", kTextFileCommaDelimitedFormat)
End Sub
vba:
Sub Main()
End if
Next
Call MsgBox("Rule Complete!")
End Sub
Dim oBOM As BOM Set oBOM = oDoc.ComponentDefinition.BOM oBOM.StructuredViewFirstLevelOnly = False oBOM.StructuredViewEnabled = True Dim oStructuredBOMView As BOMView Set oStructuredBOMView = oBOM.BOMViews.Item("Structured") Call oStructuredBOMView.Export("C:\Temp\StructuredBOM.csv", kTextFileCommaDelimitedFormat)
End Sub
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
tpascual
Hi Chandra,
Thanks for your response, I have tried yet this code, but what I mean is to export each assembly in the structure to one csv.
Export first level, and if exist some assembly export too but in a different csv.
I'm now exporting first level into a csv.
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi Tomas,
Please find the updated code to export BOM in different csv file for each assembly.
Sub Main()
    Call ExportDocStructBOM(oDoc)
    Dim oSubDoc As Document
    For Each oSubDoc In oDoc.AllReferencedDocuments
        End If
    Next
End Sub
Sub ExportDocStructBOM(oDoc As AssemblyDocument)
    Dim oBOM As BOM
    oStructuredBOMView.Export "C:\Temp\" & oDoc.DisplayName & "_StructuredBOM.csv", kTextFileCommaDelimitedFormat
End Sub
Please feel free to contact if there is any doubt.
CHANDRA SHEKAR G
Developer Advocate
tpascual
Hi Sirs,
I'm not yet tested, but it seems to work.
tpascual
Great ¡¡¡
Now I'm trying to process only assemblies in Estructured BOM not in all document.
I have phantom ass.
Any idea wellcome.
