BOLT CONNECTION DESIGN ACCELERATOR DOES NOT OFFER MY OTHER CONTENT CENTER BOLTS
NewEra_Manf
NewEra_Manf
Hello i am trying to use std. inch ANSI carriage bolts in my design accelerator / bolt connection command but it does not show nor allow a right click option to add any existing bolt styles from the content center to the bolt connection library that is available to choose from while in the command. Am i just missing a library tab/ button somewhere or is it not possible to add more faster styles to the design accelerator.
This i troubling to me since i do not want to constrain dozens of fasteners, nor do i want the wrong faster information to show up in my bill of materials and print part lists when it comes to drafting the final assembly.
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @NewEra_Manf,
Can you please explain with examples?
If screenshots are provided that would be great.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
