blurry pdf through translator add-in when drawing contains special paste table from excel
Hi everybody,
I used the translator AddIn for exporting drawings to pdfs through a macro. I literally copied the same code which appears as an example in VBA help for that purpose.
The macro works perfectly, except when I export to pdf a drawing which contains a table from an excel file pasted with special paste command.
The table appears in the pdf file in low quality and a bit blurry , but if I manually export the same drawing from Inventor, the table is exported to pdf correctly. So I guess the problem is related to the code used in the macro, but I don't get where is the problem. Any idea how could I fix it?
