blurred views in PDF exported through the API
dibujocad
dibujocad
I'm using the PDF Translator AddIn via the API to export drawings to PDF. But when I opened the PDF the views appear blurred.
I thought the reason could be that the drawing is exported before being updated. However I tried it, but it still didn't work. I also tried with "DrawingDocument.MakeAllViewsPrecise, but nothing has changed.
Any suggestion?
                    Set oAsmDrawDoc = ThisApplication.ActiveDocument
                    'Update drawing before exporting to PDF
                    oAsmDrawDoc.Update2 (True)
                    'Make all the views precise
                    oAsmDrawDoc.MakeAllViewsPrecise
                    If oAsmDrawDoc.Update2(True) = True Then
                        'Call Sub Export PDF (save drawings as PDF)
                        ExportPDF
                        'Save the updated document
                        oAsmDrawDoc.Save2 (True)
                        'Close AsmDrawDoc and active oAsm again
                        oAsmDrawDoc.Close
                    End If
Thanks in advance
bshbsh
are those shaded views? are they using bitmaps with low resolution maybe?
jR0sal3s
this is what i used....resolution at 400 or set it higher.
' Get the PDF translator Add-In.
Dim PDFAddIn As TranslatorAddIn
Set PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
'Set a reference to the active document (the document to be published).
Dim oDocument As Document
Set oDocument = ThisApplication.ActiveDocument
' Check if the Document Type is a drawing. If it isn't, display a message & exit the Sub.
If (oDocument.DocumentType <> kDrawingDocumentObject) Then
MsgBox "Drawing document not available for Plotting, switch to Drawing Document", , "Drawing not found"
Set oDocument = Nothing
Exit Sub
End If
Dim oContext As TranslationContext
Set oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = kFileBrowseIOMechanism
' Create a NameValueMap object
Dim oOptions As NameValueMap
Set oOptions = ThisApplication.TransientObjects.CreateNameValueMap
' Create a DataMedium object
Dim oDataMedium As DataMedium
Set oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
' Check whether the translator has 'SaveCopyAs' options
If PDFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
' Options for drawings...
oOptions.Value("All_Color_AS_Black") = 0
oOptions.Value("Remove_Line_Weights") = 0
oOptions.Value("Vector_Resolution") = 400
oOptions.Value("Sheet_Range") = kPrintAllSheets
'oOptions.Value("Custom_Begin_Sheet") = 2
'oOptions.Value("Custom_End_Sheet") = 4
End If
dibujocad
Thanks for your reply,
No, the drawings don't have any shadows. They contain only white and black lines.
It seems to me that the root of the problem is something related to updating the drawing document.
I recently did a test to check this fact. Firstly, I created a "Sub" called "UpdateTest" so as to update and save the drawing. Then, I executed it. After that, I executed another "Sub" in order to export the drawing to PDF through the API. Then, it worked. Any blurred view appeared in the exported PDF.
However, if I execute the "Sub Update", then the views will appear blurred after exporting PDF.
I cannot completely understand it, it should be something related to how my code is written and it is executed, because the resolution isn't the issue.
Test
Public Sub UpdateTest()
Dim oAsmDoc As DrawingDocument
Set oAsmDoc = ThisApplication.ActiveDocument
oAsmDoc.Update2 (True)
oAsmDoc.Save2 (True)
End Sub
Public Sub Update()
If oAsmDoc.Update2(True) = True Then
End If
'Call Sub Export PDF through API
ExportPDF
End Sub
bshbsh
I used to have that problem when the option "enable background updates" for drawings is enabled. inventor just starts those background processes (something like invviewcompute.exe or so) but the macro continues to run, doesn't wait for those processes to complete. In my case, I disable this option in my macro before updating the views, then re-enable it after the pdf is exported.
dibujocad
Hi bshbsh,
Thank you so much for your tip. It finally works!! 🙂
