Bill of Materials - Promoted Data
tfreed
tfreed
Is there a way to get the "Promoted From" info into the data in a BOM View? See the Screenshot.
dutt.thakar
@tfreed
I think you can check only if the specific row in BOM is promoted or not using the Promoted object, but you can not get the exact data from where it is promoted through API, I guess it is not exposed, or If it is I am not sure how to reach there.
Check this for the Promoted property in Inventor API, which helps you to see if the specific row is promoted or not.
See if that helps.
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Dutt Thakar
LinkedIn
