BEND LINE DIMENSIONING
baliasM74U3
baliasM74U3
Hi All
How can i change the orientation of the bend line annotation from vertical to horizontal. Please find the attached image. i want to align the dimensions with the bend line.
YuhanZhang
Can you let me which Inventor version you are using? I tested with the horizontal bend lines and the bend notes are also horizontal when they have leaders.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
baliasM74U3
YuhanZhang
Can you try below steps:
1. Right click the bend note, and choose Edit Dimension Style.
2. In the Dimension Style edit dialog, choose the Bend Note Settings.
3. Check the Justify Text to Leader. Save change.
4. Check if the bend note text orientation changes.
If it does not work, can you share the data to us? Don't share confidential data.
Rocky Zhang
Inventor API PD
Autodesk, Inc.
YuhanZhang
Here is the snapshot:DimensionStyle.png
Rocky Zhang
Inventor API PD
Autodesk, Inc.
