Baloon and Part list with tags column
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello to All
I have two problems with my drawings. We draw little plants a we have to use univocal position+tag for each instrument (sometimes we have to use the same component more than 1 time but the tag+pos. have to be different)
- I have to assign univocal position number for each instrument. The problem begins when I have to use the same component more than 1 time in my assembly (with the same filename...). Up to now I have copied the component as many time as I need, but I think that there is the possibility to rename/change the name of the single component directly into my assembly.
- My drawing is structured:
- assembly "A" that contains assembly"B"+assembly"C"
I customized the template of baloon and partlist and added the column "tag" so when I put in my table my sub-assembly "b" I don't have any problems with baloon and part list (I could modify the value of my tag from my part list chart and automatically is reported into my ballon);
When I put my general assembly "A" into my table and select as part list "structured (existing)" (it's the only way to open and manage the single sub-assembly part list) and I wrote the value of my tag into the right column, it isn't reported into the respective baloon
As attached the example of point 2.
Many thaks in advance
