Automating the creation of an assembly with modular panels
I've spend too much time manualy creating assemblies that always contain the same parts, but in different compositions. I've tried dabling in iLogic, but coding is definitly not my strongpoint. Creating parameters and using basic formules is something I can do. I'll try and describe my situation withouth too much detail as I cannot share too much information.
The system I have to assembly consists of a module thats 400x400mm and a module of 200x200mm. These will be attached to a wall with some metal frames verticaly placed right behind each module, ranging from 300 to 1200mm with 100mm increments. Through a form that I made I can input the max width and height (for example 3500 x 6000mm) of the planned surface and then the assembly is automaticaly adjusted to fit these dimensions. However I can only do this with the 400x400 modules. The 200x200 modules should not be added at the edges. Instead they should be placed one row inwards IF the customer wants to make use of the smaller modules. The metal frames on the back should be as tall as possible, but with a max length of 1200mm.
How should I go about creating a form that will create this assembly based on the inputs of max dimenions and optional use of the smaller module? Any sources you can point me to or functions I should look into?
