You can do it like this:
Dim doc As AssemblyDocument = ThisDoc.Document
Dim occurrences = doc.ComponentDefinition.Occurrences
' Summary:
' Method that adds a new occurrence into the assembly. This method is the equivalent
' of using the Place Component command with the "Use iMate" check box checked.
' The method returns a failure if no matches are found.
' Parameters:
' FullDocumentName:
' Input string that specifies the full document name of the part or the sub-assembly.
' If only the FullFileName is specified, the master document within the file is
' used.
' PlaceAllMatching:
' Optional input Boolean that indicates whether to place multiple components corresponding
' to all iMate definition matches in the assembly. If specified to be True, multiple
' ComponentOccurrences could be returned. If specified to be False, a single ComponentOccurrence
' corresponding to the first match is returned.
' Options:
' Input NameValueMap object that specifies additional options for creating the
' occurrence. (An empty NameValueMap object can be provided). See Remarks for valid
' options.
occurrences.AddUsingiMates(FullDocumentName)
Jelte de Jong
Blog: hjalte.nl - github.com
