Automatic points on a line?
thomas_pinnington
Observer
thomas_pinnington
Observer
Observer
I am trying to export a 3d sketch to xy-coordinates, and i have the macro to do that.
The problem is that with splines it only takes the point were you actually click, so it does not take the curve into account. Is there a way of automatically ading points (possibly macro) that will add points onto a line with an even distribution/ varying numbr of points on the line?
WHolzwarth
You can place a workpoint at the start of the curve and do a rectangular pattern (number of points as needed) along the curve length.
Other method could be using an equal distance between points of pattern.
Walter Holzwarth
thomas_pinnington
Observer
Observer
Hey,
thanks for that, but is there any way to have a line interval joining all these points? i can get the work points to work with the pattern, but they dont show in the macro, only end points of lines show, so i need a load of lines connetcing these points.
Cheers
WHolzwarth
Can you show a sample?
Walter Holzwarth
lena.talkhina
Hello @thomas_pinnington  !
Great to see you here on Inventor Forum.
Did you find a solution?
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information.
If not please don't hesitate to give an update here in your topic so all members know what ́s the progression on your question is and what might be helpful to achieve what you ́re looking for. :slightly_smiling_face:
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
