Automatic multi sheet drawing for assambly and all subassambly
denis.semeniuc
denis.semeniuc
I need ilogic code for creation multi sheet drawing for assambly an all sub assambly in all levels.
Michael.Navara
Please don't confuse this forum with the free coding factory.
Please describe, what do you want to do, what do you try (ideally problematic piece of code) and specify your question. Then members of this forum can help you.
denis.semeniuc
Sorry,
I use thise code for automatic drawing sheet bay sheet and only open assambly:
Sub main
	'Dim oAsmDoc As Document = ThisDoc.Document
	Dim oAsmDoc As _Document = ThisApplication.ActiveDocument
	templateFile = "Template.idw"
	Dim oDrawingDoc As DrawingDocument = ThisApplication.Documents.Add(DocumentTypeEnum.kDrawingDocumentObject,templateFile,True)
	oDrawingDoc.Activate()
	Dim oSheet As Sheet = oDrawingDoc.Sheets.Item(1)
	Dim oPoint1 As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(oSheet.Width/4, oSheet.Height/1.25)
	Dim oPoint2 As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(oSheet.Width/1.25, oSheet.Height/3)
	Dim oView As DrawingView
	oView = oSheet.DrawingViews.AddBaseView(oAsmDoc,  oPoint2,  1/30,  ViewOrientationTypeEnum.kIsoTopRightViewOrientation,DrawingViewStyleEnum.kShadedDrawingViewStyle	)
	'oView.RotateByAngle((PI / 180), True)
	oView = oSheet.DrawingViews.AddBaseView(oAsmDoc, oPoint1, 1 / 20, ViewOrientationTypeEnum.kFrontViewOrientation, DrawingViewStyleEnum.kHiddenLineRemovedDrawingViewStyle, )
	Dim V2Point2D As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(oView.Center.X, oView.Center.Y + 10)
	Dim V3Point2D As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(oView.Center.X - 10, oView.Center.Y)
	Dim oView2 As DrawingView = oSheet.DrawingViews.AddProjectedView(oView, V2Point2D, DrawingViewStyleEnum.kFromBaseDrawingViewStyle)
	oView2.Position = ThisApplication.TransientGeometry.CreatePoint2d(oView.Center.X,  oView.Center.Y - oView.Height / 2 - oSep - oView2.Height / 2)
End Sub
, and i lyke to modif for multi sheet drawing and all subassambly with part number.
Thanks.
Michael.Navara
You can extend your code like this
Some variables have been renamed for better readability.
Sub main()
    Dim templateFile = "" ' "Template.idw"
    Dim oAsmDoc As AssemblyDocument = ThisDoc.Document
    'Main assembly drawing
    CreteAssemblyDrawing(oAsmDoc, templateFile)
    'Drawings for sub-assemblies
    For Each doc As Document In oAsmDoc.AllReferencedDocuments
        If doc.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then Continue For
        CreteAssemblyDrawing(doc, templateFile)
    Next
End Sub
Private Sub CreteAssemblyDrawing(oAsmDoc As _Document, templateFile As String)
    'Create and activate new drawing
        templateFile,
        True
    'Create sheets
    Dim numberOfSheets = 2
    For sheetNumber As Integer = 1 To numberOfSheets
        If oDrawingDoc.Sheets.Count < sheetNumber Then
            Dim size As DrawingSheetSizeEnum = DrawingSheetSizeEnum.kA4DrawingSheetSize
            Dim orientation = PageOrientationTypeEnum.kPortraitPageOrientation
            Dim oSheet = oDrawingDoc.Sheets.Add(size, orientation)
            'TODO: Add title block, border etc.
        End If
    Next
    'Get first sheet
    Dim firstSheet As Sheet = oDrawingDoc.Sheets.Item(1)
    CreateFirstSheet(firstSheet, oAsmDoc)
    'Get second sheet
    Dim secondSheet As Sheet = oDrawingDoc.Sheets.Item(2)
    CreateSecondSheet(secondSheet, oAsmDoc)
    'And so on...
End Sub
Private Sub CreateFirstSheet(oSheet As Sheet, oAsmDoc As _Document)
    'Implement you own layout for first sheet
    'Create isometric view
    Dim isoViewPosition As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(oSheet.Width / 1.25,
        oSheet.Height / 3)
    Dim isoView = oSheet.DrawingViews.AddBaseView(
        oAsmDoc,
        isoViewPosition,
        1 / 30,
    'Create frontView
    Dim frontViewPosition As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(oSheet.Width / 4,
        oSheet.Height / 1.25)
    Dim frontView = oSheet.DrawingViews.AddBaseView(
        oAsmDoc,
        frontViewPosition,
        1 / 20,
    'NOT USED
    'Dim V3Point2D As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(frontView.Center.X - 10, frontView.Center.Y)
    'Get top view initial position
    'Dim topViewPosition As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(frontView.Center.X, frontView.Center.Y + 10)
    Dim topViewPosition As Point2d = frontView.Center.Copy()
    topViewPosition.Y += 10
    'Create top (projected) view
    Dim topView As DrawingView = oSheet.DrawingViews.AddProjectedView(
        frontView,
        topViewPosition,
    'Move top view to final position
    Dim oSep As Double = 1 'NOT DECLARED
    topViewPosition.Y = frontView.Center.Y - frontView.Height / 2 - oSep - topView.Height / 2
    topView.Position = topViewPosition
End Sub
Private Sub CreateSecondSheet(oSheet As Sheet, oAsmDoc As _Document)
    'TODO: Implement you own layout for second sheet
    'I reuse the same code for first sheet
    CreateFirstSheet(oSheet, oAsmDoc)
End Sub
denis.semeniuc
tahks.
"its works", only is created 2 sheets only with same assambly and each subassambly in iwd separate.
I need 1 .iwd with multi sheets for each subassambly whith part number in all levels of BOM. If assambly no have part number, ignore...
Merci.
Michael.Navara
OK,
Create new drawing once in Main() method. You have method for creation sheet layout "CreateFirstSheet()" which accepts sheet and assembly document as arguments.
Now you can create new sheet within "For Each doc As Document In oAsmDoc.AllReferencedDocuments" loop and create layout using "CreateFirstSheet(newSheet, doc)" instead of "CreteAssemblyDrawing(doc, templateFile)"
