Hi, I think the problem was the position off the views, I have the code adjusted.
You can also adjust the spacing between the views.
If this answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
Sub main
' Get the active assembly.
Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim AssyName As String = "framework:1" 'name of the SubAssy
Dim TemplateName As String = "white.dwg" 'name of the templae
Dim Scale As String = "1:1" 'scale
Dim SpacingBetweenViews As Double = 5
' Call the function that does the recursion.
TraverseAssembly(oAsmDoc.ComponentDefinition.Occurrences, 1, AssyName, TemplateName, Scale, SpacingBetweenViews)
End Sub
Private Sub TraverseAssembly(Occurrences As ComponentOccurrences, Level As Integer, Name As String, TemplateName As String, scale As String, SpacingViews As Double)
' Iterate through all of the occurrence in this collection. This
' represents the occurrences at the top level of an assembly.
Dim DesignProject = ThisApplication.DesignProjectManager.ActiveDesignProject
Dim DrawingTemplate As String = System.IO.Path.Combine(DesignProject.TemplatesPath, TemplateName)
Dim oOcc As ComponentOccurrence
For Each oOcc In Occurrences
' Check to see if this occurrence represents a subassembly
' and recursively call this function to traverse through it.
If oOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
If oOcc.Name = Name Then
Dim AssyDoc As AssemblyDocument = oOcc.Definition.Document
Dim oDrawDoc As DrawingDocument = CreateDrawing(DrawingTemplate)
CreateViews(oDrawDoc, AssyDoc, scale, SpacingViews)
End If
TraverseAssembly(oOcc.SubOccurrences, Level + 1, Name, TemplateName, scale, SpacingViews)
End If
Next
End Sub
Private Function CreateDrawing(DrawingDoc As String) As DrawingDocument
Dim result As DrawingDocument = Nothing
Try
Dim oNewDrawDoc As DrawingDocument = Nothing
oNewDrawDoc = ThisApplication.Documents.Add(DocumentTypeEnum.kDrawingDocumentObject, DrawingDoc)
result = oNewDrawDoc
Catch ex As Exception
MsgBox(ex.ToString, MsgBoxStyle.Critical, "CreateDrawing")
End Try
Return result
End Function
Private Sub CreateViews(ByVal oDrawDoc As DrawingDocument, ByVal oAssyDoc As AssemblyDocument, scale As String, SpacingViews As Double)
Try
'Set a reference to the active sheet.
Dim oSheet As Sheet = oDrawDoc.ActiveSheet
' Create the placement point object.
Dim Point1 As Double = ((oSheet.Width) / 2) - 8
Dim Point2 As Double = ((oSheet.Height) / 2) - 6
Dim oPoint As Point2d
oPoint = ThisApplication.TransientGeometry.CreatePoint2d(Point1, Point2)
'view 1 FrontView
Dim oViewFront As DrawingView = CreateBaseView(oAssyDoc, oSheet, oPoint, True, "Front", ViewOrientationTypeEnum.kFrontViewOrientation)
oViewFront.ScaleString = scale
oViewFront.ViewStyle = DrawingViewStyleEnum.kShadedDrawingViewStyle
Dim oBaseViewCenter As Point2d = oViewFront.Center
Dim obaseViewX As Double = oBaseViewCenter.X
Dim obaseViewY As Double = oBaseViewCenter.Y
Dim ViewFrontheight As Double = oViewFront.Height
Dim ViewFrontWidth As Double = oViewFront.Width
Dim oViewTop = CreateProjectedView(oViewFront, oSheet, "Top", oViewFront.Center.Y + 10)
Dim oViewSide = CreateProjectedView(oViewFront, oSheet, "Side",, oViewFront.Center.X + 10)
Dim oViewIso = CreateProjectedView(oViewFront, oSheet, "Iso", oViewFront.Center.X + 10, oViewFront.Center.Y + 10)
Dim ViewTopheight As Double = oViewTop.Height
Dim ViewTopWidth As Double = oViewTop.Width
Dim oViewTopPlace As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(obaseViewX, obaseViewY + (ViewFrontheight / 2) + (ViewTopheight / 2) + SpacingViews)
oViewTop.Position = oViewTopPlace
Dim ViewSideheight As Double = oViewSide.Height
Dim ViewSideWidth As Double = oViewSide.Width
Dim oViewSidePlace As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(obaseViewX + (ViewFrontWidth / 2) + (ViewSideWidth / 2) + SpacingViews, obaseViewY)
oViewSide.Position = oViewSidePlace
Dim ViewIsoheight As Double = oViewIso.Height
Dim ViewIsoWidth As Double = oViewIso.Width
Dim oViewIsoPlace As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(oViewSide.Center.X + (ViewSideWidth / 2), oViewTop.Center.Y + (ViewTopheight / 2))
oViewIso.Position = oViewIsoPlace
MsgBox(ex.ToString, MsgBoxStyle.Critical, "CreateViews")
End Try
End Sub
Private Function CreateBaseView(ByVal oAssyDoc As AssemblyDocument, oSheet As Sheet, oInsertionPoint2D As Point2d, Folded As Boolean, ByVal DrawingViewName As String, ByVal ViewOrientation As ViewOrientationTypeEnum) As DrawingView
Dim result As DrawingView = Nothing
Try
' Create a BaseView.
Dim oBaseView As DrawingView
oBaseView = oSheet.DrawingViews.AddBaseView(oAssyDoc, oInsertionPoint2D, 1, ViewOrientation, DrawingViewStyleEnum.kShadedDrawingViewStyle)
oBaseView.Name = DrawingViewName
result = oBaseView
MsgBox(ex.ToString, MsgBoxStyle.Critical, "CreateBaseView")
End Try
Return result
End Function
Private Function CreateProjectedView(ByVal baseView As DrawingView, sheet As Sheet, DrawingViewName As String, Optional height As Double = 0, Optional width As Double = 0) As DrawingView
Try
Dim oPositionBaseView As Point2d = baseView.Position
Dim xBaseView As Double = oPositionBaseView.X
Dim yBaseView As Double = oPositionBaseView.Y
Dim oPointBottomView2 As Point2d
oPointBottomView2 = ThisApplication.TransientGeometry.CreatePoint2d((xBaseView + width * 3), (yBaseView + height * 1.5))
'BottomView
Dim oProjected As DrawingView
oProjected = sheet.DrawingViews.AddProjectedView(baseView, oPointBottomView2, DrawingViewStyleEnum.kShadedDrawingViewStyle)
oProjected.Name = DrawingViewName
result = oProjected
MsgBox(ex.ToString, MsgBoxStyle.Critical, "CreateProjectedView")
End Try
Return result
End Functionā
