Automatic drawing from ipt - issue
p.kaminskiG7KX4
p.kaminskiG7KX4
Hello everyone,
I have some issue with ilogic code. I found code in this post:https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/ilogic-create-dimension-in-drawing/t... , This code is for automatic creation of drawing file from ipt with 2 views and one section view. I would like to implement this code to my flat parts configurator. Now I have some problem with creating drawing. The code works when the path to a specific file, on the basis of which it is to create projections, is given in line 3. I'd like drawing to automatically fetch views from the current file I just want to make. Can anyone help with this problem? The rule is named "Rysunek" in ipt file.
A.Acheson
Hi @p.kaminskiG7KX4
Can you attach the code your looking to work with? It will be easier ro review and make recommendations if the code is visible.
Regards
Alan
p.kaminskiG7KX4
Dim oModel As Document
Dim oSheet As Sheet
Dim oModelName As String = "C:\$ObszarRoboczyVault\Projekty Keller\Templates\OSŁONY - 2023.ipt"
oModel= ThisApplication.Documents.Open(oModelName, False)
DWGcreate = MsgBox("Stworzyć rysunek wykonawczy?", vbYesNo, "")
If DWGcreate = vbYes Then
	'określenie szablonu rysunku
	Dim IDWTemplate As String = "C:\$ObszarRoboczyVault\Projekty Keller\Templates\OSŁONY - 2023.idw"
	'tworzenie pliku rysunku
	oDrawingDoc = ThisApplication.Documents.Add(DocumentTypeEnum.kDrawingDocumentObject, IDWTemplate, True)
	oDrawingDoc.Activate()
	oSheet = oDrawingDoc.Sheets.Item(1)
	'tworzenie rzutu bazowego
	Dim oPoint1 As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(7,10)
	oBaseView = oSheet.DrawingViews.AddBaseView(oModel, oPoint1, 1, ViewOrientationTypeEnum.kLeftViewOrientation, DrawingViewStyleEnum.kHiddenLineDrawingViewStyle)
	'tworzenie rzutów
	Dim otopview As DrawingView
		Dim oPoint2 As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(7,23)
		otopview = oSheet.DrawingViews.AddProjectedView(oBaseView, oPoint2, DrawingViewStyleEnum.kFromBaseDrawingViewStyle)
	Dim osideview As DrawingView
		Dim oPoint3 As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(23,7)
		osideview = oSheet.DrawingViews.AddProjectedView(oBaseView, oPoint3, DrawingViewStyleEnum.kFromBaseDrawingViewStyle)
	'przekroje
	Dim oSectionSketch As DrawingSketch
	oSectionSketch = obaseview.Sketches.Add
	oSectionsketch.edit()
	Dim oSectionLine As SketchLine
	oSpoint1 = ThisApplication.TransientGeometry.CreatePoint2d(0, -7)
	oSpoint2 = ThisApplication.TransientGeometry.CreatePoint2d(0, 7)
	oSectionLine = oSectionSketch.SketchLines.AddByTwoPoints(oSPoint1, oSPoint2)
	oSectionSketch.ExitEdit()
	Dim osectionview As SectionDrawingView
	oSpoint3 = ThisApplication.TransientGeometry.CreatePoint2d(35,23)
		osectionview = oSheet.DrawingViews.AddSectionView(obaseview, oSectionSketch, oSPoint3, DrawingViewStyleEnum.kShadedDrawingViewStyle, 1, True, "A")
End If
A.Acheson
Hi @p.kaminskiG7KX4
If you want to start from a part then you will need the part document object. This can be done with the ilogicAPI method which is ThisDoc.Document or the Inventor API method ThisApplication.ActiveDocument.
Dim oModel As PartDocument = ThisDoc.Document
'Dim oModel As PartDocument = ThisApplication.ActiveDocument Dim oSheet As Sheet Dim oModelName As String = "C:\$ObszarRoboczyVault\Projekty Keller\Templates\OSŁONY - 2023.ipt" oModel= ThisApplication.Documents.Open(oModelName, False)
Regards
Alan
