autodesk inventor with command line interface
Can I export DWG file to DWF format with some restriction like  print disable using inventor's command like interface and no GUI ?
Rob67ert
In Inventor we don't have a command line.
What you can do is use iLogic for it.
Robert
If you find this reply helpful ? It would be nice if you use the Accept as Solution or Kudos button below.
Hey ,
      Thanks for your reply.
     I used ilogic for that it is working but I want to export dwg file to dwf without starting inventor.
So is there way to run ilogic  in headless mode or without GUI?
and can i use rule define previously ?
     Please let me know as early as possible
       Thank You!!
Rob67ert
iLogic only runs within Inventor.
You should look at VBA for that i guess, but that is something i don;t know.
Robert
Ok .thanks
