Autodesk Inventor 2023.3 Update breaks some Add-ins
Maxim-CADman77
Maxim-CADman77
It was noticed that Nifty Attributes (a kind of descendant of Attribute Helper*) by @BrianEkins can not be used after updating Autodesk Inventor from 2023.2 to 2023.3 (after pressing Add-In's ribbon button the Add-In's window shows for just a moment and then closes by itself).
Part of SDK-UserTools.
UPDATE:
Nifty Attributes works fine in Inventor 2024.
Please vote for Inventor-Idea Text Search within Option Names
Replies (16)
bradeneuropeArthur
Could you give the exact reference to what add-in you mean?
Arthur Knoors
Autodesk Affiliations:
Maxim-CADman77
My initial post contains hyperlink to Nifty Attributes Add-In homepage (https://ekinssolutions.com/nifty_attributes/).
bradeneuropeArthur
Seems that this tool is already in Inventor, per default.
That is why you cannot load it twice!
Arthur Knoors
Maxim-CADman77
You mean that Inventor 2023 has some built-in Add-in to work with attributes ... which is not present in 2024 (see UPDATE in the 1st message of this thread)?
bradeneuropeArthur
Not sure if it is not available in 2024. But in 2023 it is present per default.
Arthur Knoors
Maxim-CADman77
I believe I don't have any bulit-in Add-ins to work with Attributes in Inventor 2023.
Here is the list of add-ins built-into AI 2023 (printed with iLogic):
3d Annotation
Additive Manufacturing
Anark 3D PDF Publishing
Assembly Bonus Tools
Auto Limits
BIM Content
BIM Simplify
Content Center
Design Accelerator
Design Checker
Drag & Drop Interoperability
ESKD Support
FeedbackAddIn
Frame Generator
Fusion 360 Interoperability
iCopy
iLogic
Interactive Tutorial
Inventor Studio
Mold Design
Presentations
Routed Systems: Cable & Harness
Routed Systems: Tube & Pipe
Shared Views
Simulation: Dynamic Simulation
Simulation: Frame Analysis
Simulation: Stress Analysis
Which one conflicts with Nifty Attributes?
bradeneuropeArthur
Can you have a look in the toolstab of inventor. For me it is there in 2023!
Arthur Knoors
Maxim-CADman77
Here is how Tools Tab looks for me before I install Nifty Attributes (and after I uninstall it):
robertast
@bradeneuropeArthur   can you show me where you see it? If you are talking about the ability to assign attributes already in the inventory, then this is not the same thing
@johnsonshiue  see this looks like bug 2023.3 update
bradeneuropeArthur
here:
Arthur Knoors
Maxim-CADman77
I believe you have it present because you've installed SDK-UserTools* (C:\Users\Public\Documents\Autodesk\Inventor 2023\SDK\UserTools.MSI), right?
But the main question is: whether It works as expected after installing Update 2023.3 ? (for me it doesn't - the same problem - it's window closes by itself half-second after I press the button to show it).
That's how I can get it.
bradeneuropeArthur
This does not install the add-in if i am right. this only unpack the vb.net projects.
Did not install that. I still think it comes shipped with inventor.
Arthur Knoors
Mike.Wohletz
I don't know if it has anything to do with the 2023.3 updates, but I will concur that it does not work as it shows a quick flash of the dialog and then is gone. I don't have any other add-ins that do not work and that is good because I find this post when I am past the 50% mark of updating about 160 clients tonight.
robertast
Most likely this is a problem in 2023.3 since it works again in 2024
 @CGBenner   What do you think?
Felix-Saibel
Nifty Attributes is working fine.... many thanks!!!
Maxim-CADman77
FYI, Brian have fixed this problem in version 3.2 (I've checked and confirm this):
BTW, 'Nifty Attributes' can now be loaded simultaneously with Attribute helper:
... yet 'Attribute Helper' is useless (obsolete) for actual Inventor releases.
