Assistance Classifying Frame generated Members
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all, I'm working on a way to determine if frame generated members are unique or duplicates of another member in a frame, and then assign them the existing part number or a new one as required. The part numbering is being done to match the rest of my general assembly, there's some loose rules in the code already, but I'm going to refine this as I go. Note I use a lot of tube laser and other processing so using the standard 50 X 50 RHS - 500 doesn't work as I often have two parts the same length with different features and need to be able to assign both different part numbers easily.
In any case I've got a script currently that's pulling a bunch of information from each frame member, for now I'm just logging the info. I'm obtaining the following properties: Material, Stock No, Length, Mass, Volume, Surface Area, Ixx, Iyy, Izz. Currently I'm just logging the data, will sort once I've confirmed I'm getting the right outputs.
Obviously, plan is to sort by the easy things first (Material, Stock No, Length, Mass, Volume, Surface Area) and then if these all matches do a follow check of the centers of gravity. If there's two pieces of RHS with holes in slightly different locations, mass, surface area and volume will all match. This is fine I've sorted this, however if I have two pieces of RHS that are mirror images (see attached image or attached inventor file), the centers of gravity are coming back as identical.
I've had a look through the API help, and also this post which is somewhat similar (Solved: Accessing Inertial Properties using iLogic - Autodesk Community - Inventor), if anyone is able to offer any assistance it would be much appreciated.
All rules are in the "Classifying assistance folder - TEST FRAME"
The relevant part of the rule is here:
Private Sub FrameProcessor(BOMRows As BOMRowsEnumerator, AssemblyPNo As String) 'Interate through the contents of the Frame Dim frame As New Frame_Data Dim prelim As String Dim postlim As Single Dim MassProps As MassProperties For i As Integer = 1 To BOMRows.Count 'Get the current row Dim Row As BOMRow = BOMRows.Item(i) 'Reference to the primary component definition of the Row Dim Compdef As ComponentDefinition = Row.ComponentDefinitions.Item(1) 'Check if it is the reference Skeleton If Compdef.Document.DocumentInterests.HasInterest("SkeletonDoc") Compdef.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value = (AssemblyPNo + "-SKELETON FRAME") Logger.Info(Compdef.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value + " Is a skeleton frame") 'Check if its a frame member ElseIf Compdef.Document.DocumentInterests.HasInterest("FrameMemberDoc") Logger.Info(Compdef.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value + " Is a frame part") frame.Material = Compdef.Document.PropertySets.Item("Design Tracking Properties").Item("Material").Value frame.Stock = Compdef.Document.PropertySets.Item("Design Tracking Properties").Item("Stock Number").Value frame.Length = Compdef.Document.PropertySets.Item(4).Item("G_L").Value prelim = Compdef.Document.PropertySets.Item("Design Tracking Properties").Item("Mass").Value If Single.TryParse(prelim, System.Globalization.NumberStyles.Float, System.Globalization.CultureInfo.InvariantCulture, postlim) frame.Mass = postlim Else Logger.Info(Compdef.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value + " - the mass for this part has not been entered correctly") End If prelim = Compdef.Document.PropertySets.Item("Design Tracking Properties").Item("Volume").Value If Single.TryParse(prelim, System.Globalization.NumberStyles.Float, System.Globalization.CultureInfo.InvariantCulture, postlim) frame.Volume = postlim Else Logger.Info(Compdef.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value + " - the mass for this part has not been entered correctly") End If prelim = Compdef.Document.PropertySets.Item("Design Tracking Properties").Item("SurfaceArea").Value If Single.TryParse(prelim, System.Globalization.NumberStyles.Float, System.Globalization.CultureInfo.InvariantCulture, postlim) frame.Area = postlim Else Logger.Info(Compdef.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value + " - the mass for this part has not been entered correctly") End If Logger.Info(" Material: " + frame.Material) Logger.Info("Stock No: " + frame.Stock) Logger.Info("Length: " + frame.Length) Logger.Info(String.Format("Mass: {0}", frame.Mass)) Logger.Info(String.Format("Volume: {0}", frame.Volume)) Logger.Info(String.Format("Surface Area: {0}", frame.Area)) MassProps = Compdef.Document.ComponentDefinition.MassProperties Dim adPrincipleMoments(0 To 2) As Double Call MassProps.PrincipalMomentsOfInertia(adPrincipleMoments(0),adPrincipleMoments(1),adPrincipleMoments(2)) Logger.Info(String.Format("Ixx: {0}", adPrincipleMoments(0))) Logger.Info(String.Format("Iyy: {0}", adPrincipleMoments(1))) Logger.Info(String.Format("Izz: {0}", adPrincipleMoments(2))) 'Check if its a standard part ElseIf Compdef.Document.DocumentType = DocumentTypeEnum.kPartDocumentObject Logger.Info(Compdef.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value + " Is a standard part") End If Next End Sub
See Full code below:
Class GlobalVariable Public RevNo As String = 0 Public AssemblyCounter As Integer = 2 Public PartCounter As Integer = 1 Public GenPartCounter As Integer = 1 End Class Public Class Frame_Data Public Property Material As String Public Property Stock As String Public Property Length As String Public Property Mass As Single Public Property Volume As String Public Property Area As String Public Property Ixx As Double Public Property Ixy As Double Public Property Iyy As Double Public Property Ixz As Double Public Property Iyz As Double Public Property Izz As Double End Class Sub Main 'Reference to the assembly document Logger.Info("Start Numbering Macro") Dim Doc As AssemblyDocument = ThisApplication.ActiveDocument Doc.Rebuild() 'Rebuild the Document Dim CmdMan As ControlDefinition CmdMan = ThisApplication.CommandManager.ControlDefinitions.Item("AppUpdateMassPropertiesCmd") CmdMan.Execute CmdMan.Execute2 (True) 'Update All Mass Properties 'Reference to the BOM Dim BOM As BOM = Doc.ComponentDefinition.BOM 'Enable Structured View 'BOM.StructuredViewEnabled = True 'Reference to the structured BomView Dim BomView As BOMView = BOM.BOMViews.Item(1) 'Set Part Numbers 'SetPartNumbers(BomView.BOMRows) 'For Each ps As PropertySet In Doc.PropertySets ' Logger.Info( ps.Name + " / " + ps.InternalName) 'For Each p As [Property] In ps 'Logger.Info( " " + p.Name + " /" + Str(p.PropId)) 'Next 'Next RevNo = (Doc.PropertySets.Item("Inventor Summary Information").Item("Revision Number").Value) Dim Part_Num As String = Doc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value 'Logger.Info(Part_Num) ResetItemCheck(BomView.BOMRows) Doc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value = "A-001" 'Logger.Info(Doc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value) Logger.Info("Initializing Complete, Begin Proccessing Assembly BOM") SetPartNumbers(BomView.BOMRows, Part_Num) End Sub Private Sub SetPartNumbers(BOMRows As BOMRowsEnumerator, PartNo As String) 'iterate through the contents of the BOM Rows Logger.Info("Begin Setting Part Number of " + PartNo) Dim SketchCounter = 1 Dim NextPartNo As String For i As Integer = 1 To BOMRows.Count 'Get the Current Row Dim Row As BOMRow = BOMRows.Item(i) 'Reference to the primary ComponentDefinition of the Row Dim CompDef As ComponentDefinition = Row.ComponentDefinitions.Item(1) 'If the Bom Row Item is a Frame Assembly then rename it to be in the Format A-***-FRAME-** 'And then begin a process to rename each frame generated part If CompDef.Document.DocumentInterests.HasInterest("FrameDoc") _ AndAlso CompDef.Document.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject _ AndAlso CompDef.Document.PropertySets.Item(4).Item("PartSet").Value = 0 CompDef.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value = "A-" + Format(AssemblyCounter, "000") + "-FRAME-" CompDef.Document.PropertySets.Item(4).Item("PartSet").Value = 1 Logger.Info(CompDef.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value + " Is a frame assembly") FrameProcessor(Row.ChildRows,PartNo) ElseIf CompDef.Document.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject _ AndAlso CompDef.Document.PropertySets.Item(4).Item("PartSet").Value = 0 'Determine if the Row is a standard assembly, rename the part and then iterate the main sub over child rows CompDef.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value = "A-" + Format(AssemblyCounter, "000") CompDef.Document.PropertySets.Item(4).Item("PartSet").Value = 1 AssemblyCounter += 1 Logger.Info(CompDef.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value + " Is a standard assembly") ElseIf CompDef.Document.DocumentType = DocumentTypeEnum.kPartDocumentObject _ AndAlso CompDef.Document.PropertySets.Item(4).Item("PartSet").Value = 1 CompDef.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value = "GEN-P-" + Format(GenPartCounter, "000") GenPartCounter += 1 CompDef.Document.PropertySets.Item(4).Item("PartSet").Value = 2 Logger.Info(CompDef.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value + " Is a general part") ElseIf CompDef.Document.DocumentType = DocumentTypeEnum.kPartDocumentObject _ AndAlso CompDef.Document.PropertySets.Item("Design Tracking Properties").Item("Volume").Value = 0 _ AndAlso CompDef.Document.PropertySets.Item(4).Item("PartSet").Value = 0 CompDef.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value = PartNo + "-LAYOUT-" + Format(SketchCounter, "00") CompDef.Document.PropertySets.Item(4).Item("PartSet").Value = 1 SketchCounter += 1 Logger.Info(CompDef.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value + " Is a Layout Sketch") ElseIf CompDef.Document.PropertySets.Item(4).Item("PartSet").Value = 0 'Determine if the Row is a standard part, rename the part using the Convention A-***-P-***-** where the last two characters are the revision number 'NextPartNo = PartNo + "-P-" + Format(PartCounter, "000") 'CompDef.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value = (NextPartNo) 'PartCounter += 1 CompDef.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value = "P-" + Format(PartCounter, "000") CompDef.Document.PropertySets.Item(4).Item("PartSet").Value = 1 PartCounter += 1 Logger.Info(CompDef.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value +" is a standard part") End If 'Logger.Info(CompDef.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value) 'If CompDef.Document.DocumentInterests.HasInterest("{AC211AE0-A7A5-4589-916D-81C529DA6D17}") 'Logger.Info("This is a Frame Generated Part") 'Else 'Logger.Info("This is a Standard Part") 'End If Next For i As Integer = 1 To BOMRows.Count Dim Row As BOMRow = BOMRows.Item(i) Dim CompDef As ComponentDefinition = Row.ComponentDefinitions.Item(1) If Not Row.ChildRows Is Nothing _ And Not CompDef.Document.DocumentInterests.HasInterest("FrameDoc") SetPartNumbers(Row.ChildRows, CompDef.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value) End If Next Logger.Info("Part Numbering of " + PartNo + " is complete") End Sub Private Sub FrameProcessor(BOMRows As BOMRowsEnumerator, AssemblyPNo As String) 'Interate through the contents of the Frame Dim frame As New Frame_Data Dim prelim As String Dim postlim As Single Dim MassProps As MassProperties For i As Integer = 1 To BOMRows.Count 'Get the current row Dim Row As BOMRow = BOMRows.Item(i) 'Reference to the primary component definition of the Row Dim Compdef As ComponentDefinition = Row.ComponentDefinitions.Item(1) 'Check if it is the reference Skeleton If Compdef.Document.DocumentInterests.HasInterest("SkeletonDoc") Compdef.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value = (AssemblyPNo + "-SKELETON FRAME") Logger.Info(Compdef.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value + " Is a skeleton frame") 'Check if its a frame member ElseIf Compdef.Document.DocumentInterests.HasInterest("FrameMemberDoc") Logger.Info(Compdef.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value + " Is a frame part") frame.Material = Compdef.Document.PropertySets.Item("Design Tracking Properties").Item("Material").Value frame.Stock = Compdef.Document.PropertySets.Item("Design Tracking Properties").Item("Stock Number").Value frame.Length = Compdef.Document.PropertySets.Item(4).Item("G_L").Value prelim = Compdef.Document.PropertySets.Item("Design Tracking Properties").Item("Mass").Value If Single.TryParse(prelim, System.Globalization.NumberStyles.Float, System.Globalization.CultureInfo.InvariantCulture, postlim) frame.Mass = postlim Else Logger.Info(Compdef.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value + " - the mass for this part has not been entered correctly") End If prelim = Compdef.Document.PropertySets.Item("Design Tracking Properties").Item("Volume").Value If Single.TryParse(prelim, System.Globalization.NumberStyles.Float, System.Globalization.CultureInfo.InvariantCulture, postlim) frame.Volume = postlim Else Logger.Info(Compdef.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value + " - the mass for this part has not been entered correctly") End If prelim = Compdef.Document.PropertySets.Item("Design Tracking Properties").Item("SurfaceArea").Value If Single.TryParse(prelim, System.Globalization.NumberStyles.Float, System.Globalization.CultureInfo.InvariantCulture, postlim) frame.Area = postlim Else Logger.Info(Compdef.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value + " - the mass for this part has not been entered correctly") End If Logger.Info(" Material: " + frame.Material) Logger.Info("Stock No: " + frame.Stock) Logger.Info("Length: " + frame.Length) Logger.Info(String.Format("Mass: {0}", frame.Mass)) Logger.Info(String.Format("Volume: {0}", frame.Volume)) Logger.Info(String.Format("Surface Area: {0}", frame.Area)) MassProps = Compdef.Document.ComponentDefinition.MassProperties Dim adPrincipleMoments(0 To 2) As Double Call MassProps.PrincipalMomentsOfInertia(adPrincipleMoments(0),adPrincipleMoments(1),adPrincipleMoments(2)) Logger.Info(String.Format("Ixx: {0}", adPrincipleMoments(0))) Logger.Info(String.Format("Iyy: {0}", adPrincipleMoments(1))) Logger.Info(String.Format("Izz: {0}", adPrincipleMoments(2))) 'Check if its a standard part ElseIf Compdef.Document.DocumentType = DocumentTypeEnum.kPartDocumentObject Logger.Info(Compdef.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value + " Is a standard part") End If Next End Sub Private Sub ResetItemCheck(BOMRows As BOMRowsEnumerator) 'The purpose of this sub it to create and reset a property at 0 that will be used to determine if a part has already been renumbered 'Iterate through the contents of the BOM Row For i As Integer = 1 To BOMRows.Count 'Get The Current Row Dim Row As BOMRow = BOMRows.Item(i) 'Reference the primary ComponentDefinition of the row Dim CompDef As ComponentDefinition = Row.ComponentDefinitions.Item(1) Try CompDef.Document.PropertySets.Item(4).Item("PartSet").Value = 0 Catch CompDef.Document.PropertySets.Item(4).Add(Row.ItemQuantity, "PartSet") End Try If Not Row.ChildRows Is Nothing Then ResetItemCheck(Row.ChildRows) End If Next End Sub
