Assembly workaxes, does AddByLineAndPoint, API help file error
oransen
oransen
The help file that many functions do not work in the assembly, but the warning is missing in the AddByLineAndPoint:
Method that creates a new work axis that is parallel to a line and passes through the input point.
I've just discovered that the warning does exist in the detailed page, but not in the overview.
I think the main help file page for WorkAxes Object needs updating.
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @oransen,
You mean to say that, warning is missing at "WorkAxes" object.
That means, the line "This method is not currently supported when creating a work axis within an assembly." is missing at the end of description for "AddByLineAndPoint" method as shown below.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
oransen
Exactly!
