Apprentice Viewer Background Colour
ianjwellings
ianjwellings
I'm currently using the Apprentice Viewer to view Inventor files in my C# application. Is there any way to change the viewer background colour from blue to white?
JelteDeJong
You did not specify how you get the images, but i guess you use the camera class. Brian Ekins wrote a greate post about using the camera. you can find it here. In that post you will find the following code. in the last lines he shows how to set the background color when the picture is saved.
Private Sub CreateImage( _
              Apprentice As Inventor.ApprenticeServerComponent, _
              PartOrAssembly As Inventor.ApprenticeServerDocument, _
              Filename As String)
   ' Create a new camera.
   Dim cam As Inventor.Camera
   cam = Apprentice.TransientObjects.CreateCamera
   ' Associate the document with the camera.
   cam.SceneObject = PartOrAssembly.ComponentDefinition
   ' Define the camera and apply the changes.
   cam.ViewOrientationType = _
        Inventor.ViewOrientationTypeEnum.kIsoTopRightViewOrientation
   cam.Fit()
   cam.ApplyWithoutTransition()
   ' Save the result, defining the background color of the image.
   cam.SaveAsBitmap(Filename, 800, 600, _
           Apprentice.TransientObjects.CreateColor(255, 255, 0), _
           Apprentice.TransientObjects.CreateColor(15, 15, 15))
End Sub
Jelte de Jong
Blog: hjalte.nl - github.com
ianjwellings
Thank you for the quick response.
I'd like to change the background colour in the picturebox ClientView if possible? Without having to export as an image.
This is the code I'm using:
oSvr = new Inventor.ApprenticeServerComponent();
oAppDoc = oSvr.OpenWithOptions(strFullDocumentName, oDocOpenOptions);
oClientView = oAppDoc.ClientViews.Add(pictureBox1.Handle.ToInt32());
oCamera = oClientView.Camera;
oCamera.ViewOrientationType = Inventor.ViewOrientationTypeEnum.kIsoTopLeftViewOrientation;
oCamera.Perspective = true;
oCamera.Apply();
this.Refresh();
oClientView.Update(false);
ianjwellings
oCamera.Apply();
this.Refresh();
