Apprentice server with ilogic
Is there a way to call the  Apprentice server with ilogic rule??
jjstr8
Apprentice Server is not available from within Inventor.  It is meant to provide Inventor-like functionality in a stand-alone application.  What are you trying to do?
bradeneuropeArthur
There are possibilities to do that.
Tell us what you like to do, and we can take a look at it.
Maybe you can already use "ThisServer" within ilogic for it.
Arthur Knoors
Autodesk Affiliations:
johnster100
I was looking to do something similar. I would like to be able to set certain iproperties for every drawing in a folder (contract number, customer, etc).
The iproperties in question are used in the titleblock.
thanks,
John
