Announcements
Appending FormattedText - Labels
NachitoMax
NachitoMax
Hey
Struggling a little with appending a drawing view label. My labels are like this
I am trying to append some text to the location of the red box. If the text is already there, i want to remove it and replace it. This is how i am doing it
Dim RefText As String = "-REF-"
'example text - (SCALE - 1" = 1'-0") -REF- A101/2
'split the string at RefText to capture only the left side
Dim ChkSplitStr() As String = Split(ThisView.Label.Text, RefText)
'find the end of the formatted text next to the scale
If Strings.Right(ChkSplitStr(0), 1) = ")" Then
   'split the formatted text at RefText
   Dim SplitStr() As String = Split(ThisView.Label.FormattedText, RefText)
   'create the StyleOverride text for the append text
   Dim FormattedString as String = "<StyleOverride Font='Arial' FontSize='.025' Bold='True' Italic='False' Underline='False'>-REF- A101/2</StyleOverride>"
   'remove any right side text by using the left side formatted text
   ThisView.Label.FormattedText = SplitStr(0) & FormattedString
Sometimes it works, sometimes it doesnt. Mostly, i am getting the actual formatted string appended to the label as text instead of formatted text so, my label ends up like this
What is the best way to append FormattedText?
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
WCrihfield
When I'm modifying an existing FormattedText string, I usually use something like an InputBox (or txt file), and set the current FormattedText as the default value, to return the selectable existing string.  Then I copy/paste that back into my code and add/edit it, to make the changes I want.
Wesley Crihfield
(Not an Autodesk Employee)
marcin_otręba
hi,
could you share drawing with your label on it, or copy paste label formatted text here ?
This is (probably) problem from text wrong formatting only.
