API - Get drawingcurve circle radius
- Mute
- Permalink
- Report
I'm trying to create a small tool that adds orienations on a drawing file. In order to do so, the user must select a circle and then the program will add 0°, 90° 180° 270° text items on them.
The problem:
After I obtained the DrawingCurve I get the center point of the cirlce, but I also need the radius.
I don't know how I can get this information?
My code:
Spoiler
Private Sub Orientation_Click(sender As Object, e As EventArgs) Handles Orientation.Click
' Reference the active document
Dim oDoc As Inventor.Document
oDoc = oInvApp.ActiveDocument
' Check document type
' Only drawing files are to be saved with this code.
If Not oDoc.DocumentType = DocumentTypeEnum.kDrawingDocumentObject Then
MsgBox("Bad document type selected")
Exit Sub
End If
' Check select set for item, if none is selected let user select.
Dim oSelectSet As Inventor.SelectSet
oSelectSet = oInvApp.ActiveDocument.SelectSet
Dim oSelected_item As DrawingCurveSegment
oSelected_item = Nothing
If oSelectSet.Count <> 1 Then
oSelected_item = Pick(SelectionFilterEnum.kDrawingCurveSegmentFilter)
ElseIf oSelectSet.Count = 1 Then
oSelected_item = oSelectSet.Item(1)
End If
If oSelected_item Is Nothing Then
MsgBox("Error, please try again.")
Exit Sub
End If
Dim oDrawingCurve As DrawingCurve
oDrawingCurve = oSelected_item.Parent
Debug.Print("Selected curve type = " & oDrawingCurve.CurveType) ' Must be for circle 5124
Debug.Print("Midpoint location = " & oDrawingCurve.CenterPoint.X & " - " & oDrawingCurve.CenterPoint.Y)
End Sub
Private WithEvents oInteraction As Inventor.InteractionEvents
Private WithEvents oSelect As Inventor.SelectEvents
Private oStillSelecting As Boolean
Public Function Pick(filter As SelectionFilterEnum) As Object
' Initialize flag
oStillSelecting = True
' Create a new interactionevent object
oInteraction = oInvApp.CommandManager.CreateInteractionEvents
' Set the prompt
oInteraction.StatusBarText = "Select an circle."
' Ensure the interaction is enabled
oInteraction.InteractionDisabled = False
' Connect to the associated select events
oSelect = oInteraction.SelectEvents
' Define that all circles should be selectable
oSelect.AddSelectionFilter(filter)
' Enable single selection
oSelect.SingleSelectEnabled = True
' Start the selection process
oInteraction.Start()
' Loop untill a selection is made
Do While oStillSelecting
oInvApp.UserInterfaceManager.DoEvents()
Loop
' Get the selected item
Dim oSelectedEntity As ObjectsEnumerator
oSelectedEntity = oSelect.SelectedEntities
If oSelectedEntity.Count > 0 Then
Pick = oSelectedEntity.Item(1)
Else
Pick = Nothing
End If
' Stop the selection process
oInteraction.Stop()
' Clean up.
oSelect = Nothing
oInteraction = Nothing
End Function
Private Sub Event_Terminates() Handles oInteraction.OnTerminate
' Set the flag to indicate we're done.
oStillSelecting = False
End Sub
Private Sub Event_OnSelect(ByVal JustSelectedEntities As ObjectsEnumerator, ByVal SelectionDevice As SelectionDeviceEnum, ByVal ModelPosition As Point, ByVal ViewPosition As Point2d, ByVal View As View) Handles oSelect.OnSelect
End Sub
Exit Sub
End If
End If
Exit Sub
End If
End Sub
' Initialize flag
' Set the prompt
Loop
Else
Pick = Nothing
End If
oInteraction.Stop()
' Clean up.
oSelect = Nothing
End Function
End Sub
End Sub
I need the radius to I can determinate the position of my orientation text point
0° = (center point Y + radius); center point X
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
