API - Create iLogic Rule & add event trigger
Jef_E
Jef_E
Is it possible to create a NEW rule via the Inventor API and add a Event trigger to it?
OR
Is it possible to suppress/unsuppress a ilogic rule?
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
MechMachineMan
Yes, Yes, And Yes.
It is all through iLogicVb.Automation.
ie;
To supress a rule:
iLogicVb.Automation.GetRule(ThisDoc.Document, "Part Info").IsActive = False
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Jef_E
And how can I use this in my vb.net program?
This snippit you gave me is accepted by iLogic but not by visual studio?
Inventor 2014 SP2
MechMachineMan
Call the iLogic Add-in within the inventor app of your visual studio object.
There is also the .dll / reference for the iLogic add-in which you will need to include.
Justin K
Jef_E
Can't seem to find the .dll to add as reference.. Can only find the Autodesk.Inventor.Interop.dll
Where do i look for the iLogic.dll?
Inventor 2014 SP2
MechMachineMan
I may have mislead you a bit there; I haven't actually made add-ins myself and am not too familiar with the nitty-gritty details.
BUT:
The good ol' Google-Fu looks like it can help you out more than I ever could.
http://lmgtfy.com/?q=how+to+reference+iLogic+in+an+add-in
Justin K
