API Call woodwork application Python (WW4I)
cavallerin
cavallerin
How can I create an instance for woodwork 4 inventor addin inside a python script?
import win32com.client as wc
# istanzio l'applicazione di inventor
try:
    inv = wc.GetActiveObject('Inventor.Application')
    ww = inv.woodworkApplication
except:
    inv = wc.Dispatch('Inventor.Application')
    inv.Visible = True
Michael.Navara
Hi @cavallerin
Woodwork is an add-in for Inventor, not built-in component.
All you can try is to get its Automation property and look, if it provides any API functions. Unfortunately this property usually returns NULL or some unknown object.
cavallerin
Ok thx a lot it worked, but to get the WW4I object I use this calling:
ww = inv.ApplicationAddIns.Item(49).Automation
where 49 is the progressive number of the addin in my system.
Maybe I'm wrong, but does Inventor use internal Id(s) to identify this objects? Is there a way to get it?
Michael.Navara
If number 49 works now, you can obtain its ClientId and use it instead of this index. This Client id is persistent for whole lifecycle of the addin.
ww4iClientId=inv.ApplicationAddins.Item(49).ClientId
ww = inv.ApplicationAddIns.ItemById(ww4iClientId).Automation
# Or
ww = inv.ApplicationAddIns.ItemById('WW4I-CLIENTID-GUID-HERE').Automation
Sorry I'm not familiar with python. Excuse me if there are some syntax error.
cavallerin
{FEF38B5F-CACF-4647-8EE5-1F642F03C610}
got it!
But what do you mean by "This Client id is persistent for whole lifecycle of the addin." ?
A colleague of mine can set the same UUID?
Michael.Navara
It means this ClientId is the same for all versions of WW. It should be stable for future versions.
