API - Accessing material asset values
Jef_E
Jef_E
Hello there,
I'm trying to access some material properties but i'm stuck..
I want to change values for these fields. ( see image )
I used this piece of code to access the assetvalue but I cant find a way to set the value of a assetvalue (very confusing I know...
        Dim oAssetLib As AssetLibrary
        oAssetLib = _invApp.AssetLibraries.Item("MaterialLibrary")
        Dim oAsset As Asset
        oAsset = oAssetLib.MaterialAssets.Item(1)
        For Each oValue As AssetValue In oAsset
            Debug.Print(oValue.Name & ": " & oValue.ValueType.ToString)
        Next
This resulted in the output.
AssetLibID: kAssetValueTypeString
physmat_Comments: kAssetValueTypeString
physmat_Cost: kAssetValueTypeString
physmat_Keynote: kAssetValueTypeString
physmat_Keywords: kAssetValueTypeString
physmat_Label: kAssetValueTypeString
physmat_Manufacturer: kAssetValueTypeString
physmat_Mark: kAssetValueTypeString
physmat_Model: kAssetValueTypeString
physmat_Type: kAssetValueTypeChoice
physmat_URL: kAssetValueTypeString
physmat_aspects: kAssetValueTypeReference
physmat_class: kAssetValueTypeString
But how can I Set the string value for example "physmat_Cost"? I can't see anything in the API for this?
AssetValue Object
Description The AssetValue object represents a specific value within an asset. The AssetValue class is the base class for the various types of asset values.
Name Description
Application Returns the top-level parent application object. When used the context of Inventor, an Application object is returned. When used in the context of Apprentice, an ApprenticeServer object is returned.
DisplayName Gets the name of this value as seen in the Material or Appearance Browser. This can change based on the current Inventor language.
IsReadOnly Gets the boolean flag that indicates if this asset value is read-only. If True any attempted edits will fail.
Name Gets the key name of the value. This name will remain constant for all languages and is the name used as input to the Item property or the Asset object.
Parent Read-only property that returns the parent Asset object.
Type Read-only property returning kAssetValueObject indicating this object’s type.
ValueType Read-only property that returns the data type that the Value property for this AssetValue object will return.
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
Jef_E
Hmpppff okay found it myself.
            If oValue.ValueType = AssetValueTypeEnum.kAssetValueTypeString Then
                Dim oStringAssetValue As StringAssetValue
                oStringAssetValue = oValue
                Debug.Print(oValue.Name & ": " & oStringAssetValue.Value)
            End If
This is really weird in my opinion but, if it works okay :grinning_face_with_smiling_eyes: Now to figure out a way to add materials into the library..
Inventor 2014 SP2
Hi Jef_E
I found something close in what I'm looking in this post.
Can you help me in figuring out how to extract the Category Name from a Library?
I have this code but I just stuck thinking too much
Thank you in advance if you can help me on this matter
Dim oPartDoc = ThisDoc.Document
        oAssetLib = oPartDoc.Item("CategoryName")
        Dim oAsset As Asset
        oAsset = oAssetLib.MaterialAssetCategories.Item(1)
        For Each oValue As AssetCategory In oAsset
            Debug.Print(oValue.DisplayName)
        Next
