I am trying to create a 3D arc in a sketch but am getting an error "The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))"
Every part of the below code works except the final line that makes the arc in the sketch. After running the code I can manually create the arc using using the points created by the code. It is my understanding that the AddByThreePoints() wants the points by start middle end and that's how I have them so I'm not sure what the issue is.
Any help would be greatly appreciated.
SyntaxEditor Code Snippet
Sub Main() Dim oPartDoc As PartDocument oPartDoc = ThisApplication.ActiveDocument Dim oPartDef As PartComponentDefinition oPartDef = oPartDoc.ComponentDefinition Dim tg As TransienTGeometry tg = ThisApplication.TransientGeometry Dim sketch6 As Sketch3D sketch6 = oPartDef.Sketches3D.Add Dim points As Inventor.SketchPoints3D = sketch6.SketchPoints3D Dim lines As Inventor.SketchLines3D = sketch6.SketchLines3D Dim arcs As Inventor.SketchArcs3D = sketch6.SketchArcs3D X1 = 19.3471 Y1 = 0.72775 Z1 = 111.147 X2 = 19.2853 Y2 = -0.2478 Z2 = 111.509 X3 = 19.2512 Y3 = 0.42015 Z3 = 111.801 Dim pointArray(2) As Inventor.SketchPoint3D pointArray(0) = points.Add(tg.CreatePoint(X1, Y1, Z1) ) pointArray(1) = points.Add(tg.CreatePoint(X2, Y2, Z2) ) pointArray(2) = points.Add(tg.CreatePoint(X3, Y3, Z3) ) Dim line2 As Inventor.SketchLine3D line2 = lines.AddByTwoPoints(pointArray(0), pointArray(1)) ' Create Arc Dim arc1 As Inventor.SketchArc3D arc1 = arcs.AddByThreePoints(pointArray(1), pointArray(2), pointArray(0)) End Sub
Please try using a regular Point (not SketchPoint3D) for the midpoint of the arc:
Dim pointArray(2) As Inventor.SketchPoint3D Dim oMidPoint As Point Set oMidPoint = tg.CreatePoint(X3, Y3, Z3) Set pointArray(0) = points.Add(tg.CreatePoint(X1, Y1, Z1)) Set pointArray(1) = points.Add(tg.CreatePoint(X2, Y2, Z2)) Dim line2 As Inventor.SketchLine3D Set line2 = lines.AddByTwoPoints(pointArray(0), pointArray(1)) ' Create Arc Dim arc1 As Inventor.SketchArc3D Set arc1 = arcs.AddByThreePoints(pointArray(1), oMidPoint, pointArray(0))
Lubomir
