All Components Enabled in an Assembly
checkcheck_master
Message 1 of 1
checkcheck_master
I have a button that makes all components 'Enabled' in an assembly.
When I then apply a constraint and click OK, the constraint has not been created and the components that were previously Not Enabled are again set to Not Enabled, see video.
It seems that 'Enabled = True' is not doing its job?
Does it have to be different? See code.
Sub Main
   Try
	   ' Get the active assembly.
		Dim oAssyDoc As AssemblyDocument
		oAssyDoc = ThisApplication.ActiveDocument
		' Undo Wrapper
		Dim trans As Transaction = ThisApplication.TransactionManager.StartTransaction(oAssyDoc, "Do your thing")
			TraverseAssembly(oAssyDoc.ComponentDefinition.Occurrences)
			iLogicVb.UpdateWhenDone = True
		' Undo Wrapper
		trans.End()
	Catch
		' No Assembly?
	End Try
End Sub
Sub TraverseAssembly(oOccs As ComponentOccurrences, Optional entityName As String = "")
    ' Iterate through all of the occurrence in this collection
	Dim oOcc As ComponentOccurrence
	For Each oOcc In oOccs
		'If oOcc.Visible = True Then
			'If oOcc.Enabled = False Then oOcc.Enabled = True
		'End If
		oPart = Component.InventorComponent(oOcc.Name)
		oPart.Enabled = True
		' Use DoEvents to force Inventor to wait till the code is finished...
		Call ThisApplication.UserInterfaceManager.DoEvents
		' Recursively call sub if needed
		If oOcc.DefinitionDocumentType = kAssemblyDocumentObject Then
			Call TraverseAssembly(oOcc.SubOccurrences)
	Next
End Sub
Replies (0)
