All 3 Dimension in 1 plan view of foundation drawing from Inventor 3D model
Hi Autodesk Community,
First off I want to say how helpful it has been to pose questions here and search the database of questions that others have posted! It's awesome to see everyone involved in helping each other out. I'm looking for some iLogic Code that will allow me to populate foundation level in 2D drawing (.idw or Inventor .dwg). We work in a non-vaulted system with many project files (IPJ's). I would like to see if it is possible to get some iLogic code (rule or form is fine) that can be launched in 2D Drawing which allows me to manually give all 3 Dimension in 1 plan view of foundation drawing, it is easy to give 2D Dimension on 2D drawing but there is no such a command to populate 3rd dimension on same view, Also I want to set any of plane as 0 out of three planes in 3D model and want populate this 0 reference value in 2D drawing of that particular 3D model. Also if I set 0 plane in 3D model then I'm looking for command or iLogic Code that will allow to populate 3rd dimension from 0 reference plane and these dimensions are adaptive, means if changed in 3D model it should be update in Plan view also, the dimension may be positive or negative as I'm considering above the 0 reference plane is positive and below it negative.
