Algorihtm to get primitive names
Ruffy85
Ruffy85
Hey there!
this is not so easy i think.
i need help. i need simple primitve names when i create my model with single solidbodies.
For example, i use the primitve box and a primitive cylinder. i create both in different solid bodies.
Is there a way to get the information, that solidbody1 = BOX and solidbody2 = cylinder?
But it has to be safe that if the user creates a box through the standard way (2d sketch and extrusion) but with not parallel faces, that the algorithm knows that.
So does anyone has created a method for get these results? maybe with vectorbased calcualtions? to check if the faces around a rectangle to the each other (for box) or cylindrical face with 2x plane faces or something like that. i have no idea! At first a box should be enough,
Big thanks for helping!
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Ruffy85
can be closed,
find a other way to solve my origin problem.
thanks
