Adicion de columnas claves en iparts
johannes_santos
johannes_santos
Buenas compañeros, actualmente estoy realizando la publicación de un elemento en el centro de contenido y cuando pongo las columnas claves me permite hasta 9, hay alguna manera de tener mas? O definitivamente solo se puede hasta 9?.
Gracias
FINET_Laurent
Hola @johannes_santos,
Unfortunately there is no way to increase the limit. Have you considered using iLogic parts & Place iLogic Component functionalities ?
Kind regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
johannes_santos
Thank you very much for the answers, I have not tried it with ilogic because I don't use it very well
