Adding revision number exported to filename
jordyCVWSE
jordyCVWSE
A while ago i struggled with the below code and with your help i've worked with it pleasently. Now the question is to add the revision number of the exported document to the filename (if there is a revision number).
This code is used to export current or all open drawings to PDF and/or DWG. This saves a lot of time to export 50+ drawings of a project.
When i edit the code i'm coming to 2 outcome's:
1. it is looking at the revision number of the shown model and not the drawings revision number.
2. it is only looking at the current open drawing's revision number and adding it to all filenames.
Now i can update the revision numbers to the models by hand, but that's not ideal.
Sub Main()
	oInvApp = ThisApplication
	Dim myDate As String = Now().ToString("dd-MM-yyyy")
	myDate = myDate.Replace(":","")  ' & " - " & TypeString
	userChoice = InputRadioBox("Defined the scope", "This Document", "All Open Documents", True, Title := "Defined the scope")
	UserSelectedActionList = New String(){"DWG & PDF", "PDF Only", "DWG Only"}
	UserSelectedAction = InputListBox("What action must be performed with selected views?", _
	UserSelectedActionList, UserSelectedActionList(0), Title := "Action to Perform", ListName := "Options")
	Select UserSelectedAction
	Case "DWG & PDF": UserSelectedAction = 3
	Case "PDF Only": UserSelectedAction = 1
	Case "DWG Only": UserSelectedAction = 2
	End Select
	If userChoice Then
		Call MakePDFFromDoc(oInvApp.ActiveDocument, myDate, UserSelectedAction)
	Else
		For Each oDoc In oInvApp.Documents
			If oDoc.DocumentType <> kDrawingDocumentObject Then Continue For
			Try
				If Len(oDoc.File.FullFileName) > 0 Then
					Call MakePDFFromDoc(oDoc, myDate, UserSelectedAction)
				End If
			Catch
			End Try
		Next
	End If
 End Sub
 Dim oInvApp As Inventor.Application
 Sub MakePDFFromDoc(ByRef oDocument As Document, DateString As String, UserSelectedAction As Integer)
	'oPath = oDocument.Path
	'oFileName = oDocument.FileName(False) 'without extension
	'oDocument = ThisApplication.ActiveDocument
	Dim sDescript As String = oDocument.PropertySets("Design Tracking Properties")("Description").Value
	oPDFAddIn = oInvApp.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
	oContext = oInvApp.TransientObjects.CreateTranslationContext
	oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
	oOptions = oInvApp.TransientObjects.CreateNameValueMap
	oDataMedium = oInvApp.TransientObjects.CreateDataMedium
	oFullFileName = oDocument.File.FullFileName
	oPath = Left(oFullFileName, InStrRev(oFullFileName, "\")-1)
	oFileName = Right(oFullFileName, Len(oFullFileName)-InStrRev(oFullFileName, "\"))
'	oFilePart = Left(oFileName, InStrRev(oFileName, ".") - 1)
	oFilePart = Left(oFileName, InStrRev(oFileName, ".") - 1) & " " & sDescript
	'oRevNum = oDocument.iProperties.Value("Project", "Revision Number")
	'If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
	oOptions.Value("All_Color_AS_Black") = 0
	oOptions.Value("Remove_Line_Weights") = 1
	oOptions.Value("Vector_Resolution") = 400
	oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
	'oOptions.Value("Custom_Begin_Sheet") = 2
	'oOptions.Value("Custom_End_Sheet") = 4
	' End If
	'get PDF target folder path
	'oFolder = Left(oPath, InStrRev(oPath, "\")) & "PDF"
	oFolder = oPath & "\Export DWG & PDF (" & DateString & ")"
	oDirectoryName = System.IO.Path.GetDirectoryName(oFullFileName)
	'Check for the PDF folder and create it if it does not exist
	If Not System.IO.Directory.Exists(oFolder) Then
		System.IO.Directory.CreateDirectory(oFolder)
	End If
	'Set the PDF target file name
	oDataMedium.FileName = oFolder & "\" & oFilePart & ".pdf"
	'Publish document
	If (UserSelectedAction = 1) Or (UserSelectedAction = 3) Then
		oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)'For PDF's
	End If
	If (UserSelectedAction = 2) Or (UserSelectedAction = 3) Then
		oDocument.SaveAs(oFolder & "\" & oFilePart & ".dwg", True) 'For DWG's
	End If
	'oDocument.SaveAs(oFolder & "\" & ThisDoc.ChangeExtension(".DWG"), True) 'For DWG's
	'------end of iLogic-------
 End Sub
BM_Ashraf
Hope this helps you!
Sub Main()
	End Select
	If userChoice Then
	Else
			Try
				End If
			Catch
			End Try
		Next
	End If
 End Sub
 Sub MakePDFFromDoc(ByRef oDocument As DrawingDocument, DateString As String, UserSelectedAction As Integer)
	'REF Model
	Dim oRefModel As Document = oDocument.ReferencedDocuments.Item(1)
	oRevNum = oRefModel.PropertySets("Inventor Summary Information").Item("Revision Number").Value
	Dim oExtra As String = Nothing
	If oRevNum = "" Or  oRevNum Is Nothing Then
		oExtra = Nothing
		Else
		oExtra = "_" & oRevNum
	End If
	oFilePart = Left(oFileName, InStrRev(oFileName, ".") -1) & " " & sDescript & oExtra
	' End If
	End If
	'Publish document
	End If
	End If
 End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Blue Mech
Add-ins for Inventor!
jordyCVWSE
Thank you for the quick reply. Since the time of the post i've been puzzling in the code and found a different solution:
Maybe it is a bit rough as i am not a coder, but it worked.
also added if there is no Rev number that it doesn't show.
Sub Main()
	End Select
	If userChoice Then
	Else
			Try
				End If
			Catch
			End Try
		Next
	End If
 End Sub
	Dim sRevnum As String = oDocument.PropertySets("Inventor Summary Information")("Revision Number").Value
	If oDocument.PropertySets("Inventor Summary Information")("Revision Number").Value = "" Then
		oREV = ""
ElseIf oDocument.PropertySets("Inventor Summary Information")("Revision Number").Value  IsNot  "" Then
		oREV= " REV "
End If
	oFilePart = Left(oFileName, InStrRev(oFileName, ".") - 1) & " " & sDescript & oREV & sRevNum
	' End If
	End If
	'Publish document
	End If
	End If
 End Sub
BM_Ashraf
Well done!
Yeah, that works too.
You will face one problem if no revision exists. As you will add the Text " REV " or space " " to the file name.
Blue Mech
jordyCVWSE
		oREV = ""
		oREV= "REV "
End If
To my logic i prefent this from happening with this If section.
If there is "nothing" filled in to the revision number value, "nothing" will be added.
If something is filled into te revision number value, REV will be added in front of the Revision number value.
That is wat the goal is with this section. That REV is not always shown, only when there is a Revision.
So far it is working as intended. Tried it with multiple documents so far so good.
