this iLogic rule uses the first DrawingView on the sheet to create the back view (and rightview but that will be deleted automaticaly.)
Dim doc As DrawingDocument = ThisApplication.ActiveDocument
Dim oSheet As Sheet = doc.ActiveSheet
Dim baseView As DrawingView = oSheet.DrawingViews.Item(1)
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
Dim baseViewPosition As Point2d = baseView.Position
Dim BaseViewWidth As Double = baseView.Width
Dim rightViewPosition As Point2d = oTG.CreatePoint2d(baseViewPosition.X + 1 + BaseViewWidth / 2, baseViewPosition.Y)
Dim backViewPosition As Point2d = oTG.CreatePoint2d(baseViewPosition.X + 1 + BaseViewWidth, baseViewPosition.Y)
Dim drawingViewStyle As DrawingViewStyleEnum = DrawingViewStyleEnum.kFromBaseDrawingViewStyle
Dim rightView As DrawingView = oSheet.DrawingViews.AddProjectedView(baseView, rightViewPosition, drawingViewStyle)
Dim backView As DrawingView = oSheet.DrawingViews.AddProjectedView(rightView, backViewPosition, drawingViewStyle)
'the right view was created to create the back view but is not what you asked for, therfor it can be deleted
rightView.Delete()
' this line is not mandatory but make makes sure that the views stay aligned
backView.Align(baseView, DrawingViewAlignmentEnum.kHorizontalViewAlignment)
Jelte de Jong
Blog: hjalte.nl - github.com
