Adding / projecting back view
NachitoMax
NachitoMax
Hey
I have a method that is adding a base view to a sheet. I need to add the opposite / back view of the current view either as a separate view or projected but cant figure it out.
Anyone know a way of doing that?
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
JelteDeJong
this iLogic rule uses the first DrawingView on the sheet to create the back view (and rightview but that will be deleted automaticaly.)
Dim doc As DrawingDocument = ThisApplication.ActiveDocument
Dim oSheet As Sheet = doc.ActiveSheet
Dim baseView As DrawingView = oSheet.DrawingViews.Item(1)
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
Dim baseViewPosition As Point2d = baseView.Position
Dim BaseViewWidth As Double = baseView.Width
Dim rightViewPosition As Point2d = oTG.CreatePoint2d(baseViewPosition.X + 1 + BaseViewWidth / 2, baseViewPosition.Y)
Dim backViewPosition As Point2d = oTG.CreatePoint2d(baseViewPosition.X + 1 + BaseViewWidth, baseViewPosition.Y)
Dim drawingViewStyle As DrawingViewStyleEnum = DrawingViewStyleEnum.kFromBaseDrawingViewStyle
Dim rightView As DrawingView = oSheet.DrawingViews.AddProjectedView(baseView, rightViewPosition, drawingViewStyle)
Dim backView As DrawingView = oSheet.DrawingViews.AddProjectedView(rightView, backViewPosition, drawingViewStyle)
'the right view was created to create the back view but is not what you asked for, therfor it can be deleted
rightView.Delete()
' this line is not mandatory but make makes sure that the views stay aligned
backView.Align(baseView, DrawingViewAlignmentEnum.kHorizontalViewAlignment)
Jelte de Jong
Blog: hjalte.nl - github.com
HideoYamada
I tried another way. This code will create an opposite view directly.
Option Explicit
Sub CreateOppositeView()
    Dim oDrawingDoc As DrawingDocument
    Set oDrawingDoc = ThisApplication.ActiveDocument
    Dim oSourceView As DrawingView
    Set oSourceView = oDrawingDoc.ActiveSheet.DrawingViews(1)
    ' Document
    Dim oSourceDoc As Document
    Set oSourceDoc = oSourceView.ReferencedDocumentDescriptor.ReferencedDocument
    ' Position
    Dim oViewPosition As Point2d
    Set oViewPosition = oSourceView.Position.Copy
    oViewPosition.X = oViewPosition.X + oSourceView.Width + 1
    ' Scale
    Dim viewScale As Double
    viewScale = oSourceView.Scale
    ' ViewStyle
    Dim viewStyle As DrawingViewStyleEnum
    viewStyle = oSourceView.viewStyle
    ' ModelViewName
    Dim modelViewName As String
    modelViewName = oSourceView.ActiveDesignViewRepresentation
    ' Camera
    Dim oCamera As Camera
    Set oCamera = ThisApplication.TransientObjects.CreateCamera
    oCamera.Eye = GetOppositeEyePoint(oSourceView.Camera)
    oCamera.Target = oSourceView.Camera.Target
    oCamera.UpVector = oSourceView.Camera.UpVector
    ' Create new DrawingView
    Dim oNewDrawingView As DrawingView
    Set oNewDrawingView = oDrawingDoc.ActiveSheet.DrawingViews.AddBaseView(oSourceDoc, oViewPosition, viewScale, kArbitraryViewOrientation, viewStyle, modelViewName, oCamera)
End Sub
Function GetOppositeEyePoint(oCamera As Camera) As Point
    Dim X As Double
    Dim Y As Double
    Dim Z As Double
    X = oCamera.Target.X * 2 - oCamera.Eye.X
    Y = oCamera.Target.Y * 2 - oCamera.Eye.Y
    Z = oCamera.Target.Z * 2 - oCamera.Eye.Z
    Set GetOppositeEyePoint = ThisApplication.TransientGeometry.CreatePoint(X, Y, Z)
End Function
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
