09:27 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello Everyone,
I am trying to write a code where I want to put a part list for each individual part that is available on the drawing sheet. But I don't know how to try and catch it part.
The following code is written such that it allows to select the view and also adds the parts list for that part.
But the problem arises when I want the section cut for the projected views as well and so it adds part lists for each projected view, Despite I only need one part list for that part. Please help!
Here's the code:
Sub Main() Start: Dim oDrawDoc As DrawingDocument oDrawDoc = ThisApplication.ActiveDocument ' Select a drawing view. Dim oView As DrawingView oView = ThisApplication.CommandManager.Pick(kDrawingViewFilter, "Select a drawing view.") 'Set a reference to the active sheet. Dim oSheet As Sheet oSheet = oView.Parent Dim dXval As Double dXval = oView.Left Dim dYval As Double dYval = oView.Center.Y Dim dLeftXval As Double dLeftXval = dXval - 3 'add height to y value Dim dUpperYval As Double dUpperYval = dYval + (0.5 * oView.Height) + 1 'subract height To y value Dim dLowerYval As Double dLowerYval = dYval - (0.5 * oView.Height) - 1 'Dim oPoint1 As Point2d 'oPoint1 = ThisApplication.TransientGeometry.CreatePoint2d(oView.Center.X,dUpperYval) 'Dim oPoint2 As Point2d 'oPoint2 = ThisApplication.TransientGeometry.CreatePoint2d(oView.Center.X,dLowerYval) Dim oPoint1 As Point2d oPoint1 = ThisApplication.TransientGeometry.CreatePoint2d(dLeftXval,dUpperYval) Dim oPoint2 As Point2d oPoint2 = ThisApplication.TransientGeometry.CreatePoint2d(dLeftXval,dLowerYval) 'create a new sketch For the section Dim oDrawingSketch As DrawingSketch = oView.Sketches.Add Dim oSketchPoint1 As Point2d oSketchPoint1 = oDrawingSketch.SheetToSketchSpace(oPoint1) Dim oSketchPoint2 As Point2d oSketchPoint2 = oDrawingSketch.SheetToSketchSpace(oPoint2) oDrawingSketch.Edit Dim oSketchLine As SketchLine oSketchLine = oDrawingSketch.SketchLines.AddByTwoPoints(oSketchPoint1,oSketchPoint2) oDrawingSketch.ExitEdit 'set the location for the view Dim olocal As Point2d olocal = ThisApplication.TransientGeometry.CreatePoint2d(6,oView.Center.Y) Dim oView2 As SectionDrawingView oView2 = oSheet.DrawingViews.AddSectionView(oView, oDrawingSketch, olocal,DrawingViewStyleEnum.kFromBaseDrawingViewStyle, Nothing, , , False, True) oDrawingSketch.Visible = True 'AutoGenerate PartList Dim oPlacementPoint As Point2d oPlacementPoint = ThisApplication.TransientGeometry.CreatePoint2d(dLeftXval+22, dUpperYval+3) iLogicVb.UpdateWhenDone = True Dim oPartslist As PartsList 'Dim C As Double Try 'try to get the parts list oPartslist = oSheet.PartsLists.Item(1) Catch 'catch error when no parts list is found 'and then create one oPartslist = oSheet.PartsLists.Add(oView, oPlacementPoint) End Try 'Selection if you want to continue with section cut Dim oChoice As String oChoice = MsgBox(" Do you want to create another section cut?", vbQuestion + vbYesNo + vbDefaultButton2, "Section Cut") If oChoice = vbYes Then GoTo Start Else End If End Sub
