Announcements
Adding iFeature with VBA failed
Im trying (and failing) to add an iFeatur to a part using a VBA-Macro.
By pressing F1 on "iFeatures" in the VBA-Editor i found an exampel code but in my case it dosn't work.
I selected a Face in my testpart (attached) and then executed the vba code. It complained that i had to select a "planar face", so i commeted out the lines that checked for the planar face and run the code again. It didn't show any errors but also did not place the iFeature (attached).
I attached the IFeature, my testpart and the VBA code with the plain exampel code and my modified verison.
If anybody has any expeareance with adding features via VBA-Macros, could he or she post an exampel or explain to me how this is done?
Thanks very much
Paul.
frederic.vandenplas
I managed to let it work.
There were 2 problems, in the sample code the <> is missing
If oFace.SurfaceType <> kPlaneSurface Then
       MsgBox "A planar face must be selected."
       'Exit Sub
And then it look for a sketchplane in your iFeature.
But Sketch Plane is not available in your iFeature.
So change this
Case "Sketch Plane"
To This
Case "Skizzenposition-Ebene1"
I came across your 2nd problem with a debug.print of the needed input of your specific ifeature
Debug.Print oInput.Name
        Select Case oInput.Name
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
@frederic.vandenplas
Thank you very much for your quick help.
I tried it with the changes you suggestet and it worked flawlessly.
I attatched a fully functional exampel for future visitors of this post, the credit for witch belongs to you.
Thanks again and "KUDOS" 👍
