- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi everyone,
I would like to automate a drawing using the API functionalities. I am trying to add a simple linear dimension.
What I found online helped me to get the below working within the ipt (parts) file. This works fine:
' Get the part to be inserted into the drawing. Dim oPartDoc As PartDocument oPartDoc = ThisApplication.ActiveDocument ' Create a new drawing document using the default template. Dim oDrawDoc As DrawingDocument oDrawDoc = ThisApplication.Documents.Open( "Template.idw", True) Dim oSheet As Sheet oSheet = oDrawDoc.ActiveSheet Dim oTG As TransientGeometry oTG = ThisApplication.TransientGeometry ' Place the base front view. Dim oFrontView As DrawingView oFrontView = oSheet.DrawingViews.AddBaseView(oPartDoc, oTG.CreatePoint2d(7, 28), 0.05, ViewOrientationTypeEnum.kFrontViewOrientation, DrawingViewStyleEnum.kHiddenLineRemovedDrawingViewStyle) ' Place the base side view. Dim oSideView As DrawingView oSideView = oSheet.DrawingViews.AddBaseView(oPartDoc, oTG.CreatePoint2d(35, 35), 0.02, ViewOrientationTypeEnum.kLeftViewOrientation, DrawingViewStyleEnum.kHiddenLineRemovedDrawingViewStyle) ' Create the top view Dim oTopView As DrawingView oTopView = oSheet.DrawingViews.AddProjectedView(oSideView, oTG.CreatePoint2d(35, 20), DrawingViewStyleEnum.kHiddenLineRemovedDrawingViewStyle) ' Dimension Dim faceOrEdge1 As Object = oPartDoc.AttributeManager.FindObjects("*", "*", "Nutenseite1").Item(1) Dim myCurveCandidates As DrawingCurvesEnumerator = oTopView.DrawingCurves(faceOrEdge1) Dim myDrawingCurve As DrawingCurve = myCurveCandidates.Item(1) Dim face1GeoIntent As GeometryIntent = oSheet.CreateGeometryIntent(myDrawingCurve) Dim faceOrEdge2 As Object = oPartDoc.AttributeManager.FindObjects("*", "*", "Nutenseite2").Item(1) myCurveCandidates = oTopView.DrawingCurves(faceOrEdge2) myDrawingCurve = myCurveCandidates.Item(1) Dim face2GeoIntent As GeometryIntent = oSheet.CreateGeometryIntent(myDrawingCurve) Dim widthDimPoint As Point2d = oTG.CreatePoint2d(15, 10) oSheet.DrawingDimensions.GeneralDimensions.AddLinear(widthDimPoint,face1GeoIntent,face2GeoIntent)
I am now trying to dimension the exact same faces from the very same part within an assembly. However, the above code does not work as soon as oPartDoc is an AssemblyDocument.
My guess from my knowledge is that I am not in the right layer but that I have to somehow dive into the correct part within the assembly.
I tried to get there using things like
oPartDoc.ComponentDefinition.Occurrences.ItemByName("myPart")
instead of oPartDoc, as well as looping through it:
For i = 1 To oPartDoc.ReferencedDocuments.Count MessageBox.Show(oPartDoc.ReferencedDocuments.Item(i).DisplayName()) MessageBox.Show(oPartDoc.ReferencedDocuments.Item(i).AttributeManager.FindObjects("*", "*", "Nutenseite1").Count.ToString()) Next
but it feels like I am moving in circles.
Any suggestions please?
