adding dimensions automaticly - Rule not working properly
michielXWZ7U
michielXWZ7U
Hi folks!
I have the next problem, after i have added a view on my drawing i have this nice rule to automate the annonations needed for the people in the workshop to do the drilling of the holes. I attached the drawing document with a view added of a profile that needs holes.
- i click the rule
- i add the dimensions to the profile
so far so good! The dimensions are nicely added. Amazing
but then the HORROR starts. because i continue creating the drawing but when i push Control-z, it takes me all the way back to the moment i added the rule. As well als my Model Tree freezes.
Does anyone knows what is wrong with the code that it starts doing weird stuff?
i attached a sample document that shows my problem.
Here is the code:
Public Class ThisRule
    Private _doc As DrawingDocument
    Private _sheet As Sheet
    Private _view As DrawingView
    Private _intents As List(Of GeometryIntent) = New List(Of GeometryIntent)()
    Private _centerPointIntents As List(Of GeometryIntent) = New List(Of GeometryIntent)()
    ' Some settings here for you to change.
    Private _stackedDimensions As Boolean = True
    Private _firstOffset As Double = 0.4 'Cm
    Private _offsetDimension As Double = 0.5 'Cm
    Sub main()
	 _doc = ThisDoc.Document
        _sheet = _doc.ActiveSheet
        _view = ThisApplication.CommandManager.Pick(
                       SelectionFilterEnum.kDrawingViewFilter,
                       "Select a drawing view")
        Dim transaction As Transaction = ThisApplication.TransactionManager.StartTransaction(_doc, "Generate dimensions")
        CreateIntentList()
        ' Comment out features that you dont want/need!
        CreateHorizontalDimensions()
        CreateVerticalDimensions()
        'CreateMarks()
        AddDiameterDimensionToCircles()
        ' createHorizontalOuterDimension()
        ' createVerticalOuterDimension()
	i += 1
    End Sub
    Public Sub CreateHorizontalDimensions()
        Dim orderedIntents = _intents.OrderBy(Function(s) s.PointOnSheet.X)
        Dim orderedCenterIntents = _centerPointIntents.OrderBy(Function(s) s.PointOnSheet.X)
        Dim pointLeft = orderedIntents.First
        Dim pointRight = Nothing
        Dim lastX = pointLeft.PointOnSheet.X
        Dim offset As Double = _firstOffset
        For Each intent As GeometryIntent In orderedCenterIntents
            pointRight = intent
            If (AreEqual(pointRight.PointOnSheet.X, lastX)) Then
                Continue For
            End If
            CreateHorizontalDimension(pointLeft, pointRight, offset)
            If _stackedDimensions Then
                offset = offset + _offsetDimension
            Else
            End If
            lastX = pointRight.PointOnSheet.X
        Next
        pointRight = orderedIntents.Last
    End Sub
    Private Sub CreateHorizontalDimension(pointLeft As GeometryIntent,
                                          pointRight As GeometryIntent,
                                          distanceFromView As Double)
        Dim textX = pointLeft.PointOnSheet.X +
                (pointRight.PointOnSheet.X - pointLeft.PointOnSheet.X) / 2
        Dim textY = _view.Position.Y + _view.Height / 2 + distanceFromView
        Dim pointText = ThisApplication.TransientGeometry.CreatePoint2d(textX, textY)
        _sheet.DrawingDimensions.GeneralDimensions.AddLinear(
            pointText, pointLeft, pointRight, DimensionTypeEnum.kHorizontalDimensionType)
    End Sub
    Private Sub CreateHorizontalOuterDimension()
        Dim orderedIntents = _intents.OrderByDescending(Function(s) s.PointOnSheet.X)
        Dim pointRight = orderedIntents.Last
        CreateHorizontalDimension(pointLeft, pointRight, _firstOffset - _offsetDimension)
    End Sub
    Public Sub CreateVerticalDimensions()
        Dim orderedIntents = _intents.OrderByDescending(Function(s) s.PointOnSheet.Y)
        Dim orderedCenterIntents = _centerPointIntents.OrderByDescending(Function(s) s.PointOnSheet.Y)
        Dim lastY = pointLeft.PointOnSheet.Y
            pointRight = intent
            If (AreEqual(pointRight.PointOnSheet.Y, lastY)) Then
                Continue For
            End If
            CreateVerticalDimension(pointLeft, pointRight, offset)
            Else
                pointLeft = pointRight
            End If
            lastY = pointRight.PointOnSheet.Y
        Next
    End Sub
    Private Sub CreateMarks()
        Dim done As List(Of GeometryIntent) = New List(Of GeometryIntent)()
        Dim firstIntent = orderedCenterIntents(0)
        Dim secondIntent = Nothing
        For i = 1 To orderedCenterIntents.Count - 1
            secondIntent = orderedCenterIntents(i)
            If (AreEqual(firstIntent.PointOnSheet.Y, secondIntent.PointOnSheet.Y)) Then
                CreateCenterLine(firstIntent, secondIntent)
                done.Add(firstIntent)
                done.Add(secondIntent)
            End If
            firstIntent = secondIntent
        Next
        orderedCenterIntents = _centerPointIntents.OrderByDescending(Function(s) s.PointOnSheet.X)
            If (AreEqual(firstIntent.PointOnSheet.X, secondIntent.PointOnSheet.X)) Then
            End If
        Next
            If (done.Contains(intent)) Then
                Continue For
            End If
            _sheet.Centermarks.Add(intent)
        Next
    End Sub
    Public Sub CreateCenterLine(pointLeft As GeometryIntent, pointRight As GeometryIntent)
        Dim collection = ThisApplication.TransientObjects.CreateObjectCollection()
        collection.Add(pointLeft)
        collection.Add(pointRight)
        _sheet.Centerlines.Add(collection)
    End Sub
    Private Sub CreateVerticalDimension(pointLeft As GeometryIntent,
        Dim textY = pointLeft.PointOnSheet.Y +
                (pointRight.PointOnSheet.Y - pointLeft.PointOnSheet.Y) / 2
        Dim textX = _view.Position.X - _view.Width / 2 - distanceFromView
            pointText, pointLeft, pointRight, DimensionTypeEnum.kVerticalDimensionType)
    End Sub
    Private Sub CreateVerticalOuterDimension()
        Dim pointLeft = orderedIntents.Last
        Dim pointRight = orderedIntents.First
        CreateVerticalDimension(pointLeft, pointRight, _firstOffset - _offsetDimension)
    End Sub
    Private Sub AddIntent(Geometry As DrawingCurve, IntentPlace As Object, onLineCheck As Boolean)
        Dim intent As GeometryIntent = _sheet.CreateGeometryIntent(Geometry, IntentPlace)
        If intent.PointOnSheet Is Nothing Then Return
        If onLineCheck Then
            If (IntentIsOnCurve(intent)) Then
                _intents.Add(intent)
            End If
        Else
        End If
    End Sub
    Private Function IntentIsOnCurve(intent As GeometryIntent) As Boolean
        Dim Geometry As DrawingCurve = intent.Geometry
        Dim sp = intent.PointOnSheet
        Dim pts(1) As Double
        Dim gp() As Double = {}
        Dim md() As Double = {}
        Dim pm() As Double = {}
        Dim st() As SolutionNatureEnum = {}
        pts(0) = sp.X
        pts(1) = sp.Y
        Try
            Geometry.Evaluator2D.GetParamAtPoint(pts, gp, md, pm, st)
        Catch ex As Exception
            Return False
        End Try
        Return True
    End Function
    Private Sub CreateIntentList()
        For Each drawingCurve As DrawingCurve In _view.DrawingCurves
			Select Case DrawingCurve.ProjectedCurveType
                Case _
                        Curve2dTypeEnum.kCircleCurve2d,
                        Curve2dTypeEnum.kCircularArcCurve2d,
                        Curve2dTypeEnum.kEllipseFullCurve2d,
                        Curve2dTypeEnum.kEllipticalArcCurve2d
                    AddIntent(DrawingCurve, PointIntentEnum.kCircularTopPointIntent, True)
                    AddIntent(DrawingCurve, PointIntentEnum.kCircularBottomPointIntent, True)
                    AddIntent(DrawingCurve, PointIntentEnum.kCircularLeftPointIntent, True)
                    AddIntent(DrawingCurve, PointIntentEnum.kCircularRightPointIntent, True)
                    AddIntent(DrawingCurve, PointIntentEnum.kEndPointIntent, False)
                    AddIntent(DrawingCurve, PointIntentEnum.kStartPointIntent, False)
                    If (DrawingCurve.ProjectedCurveType = Curve2dTypeEnum.kCircleCurve2d) Then
                        Dim intent = _sheet.CreateGeometryIntent(DrawingCurve, PointIntentEnum.kCenterPointIntent)
                        _centerPointIntents.Add(intent)
                    End If
                Case _
                        Curve2dTypeEnum.kLineCurve2d,
                        Curve2dTypeEnum.kLineSegmentCurve2d
                Case _
                    Curve2dTypeEnum.kPolylineCurve2d,
                    Curve2dTypeEnum.kBSplineCurve2d,
                    Curve2dTypeEnum.kUnknownCurve2d
                    ' Unhandled curves types
                Case Else
            End Select
        Next
    End Sub
Private Sub AddDiameterDimensionToCircles()
    If _intents.Count = 0 Then
        Exit Sub
    End If
    Dim intent As GeometryIntent = _intents.Item(0)
    Dim geo = intent.Geometry
    If (geo.type <> ObjectTypeEnum.kDrawingCurveObject) Then
        Exit Sub
    End If
    Dim curve As DrawingCurve = geo
    If (curve.ProjectedCurveType <> Curve2dTypeEnum.kCircleCurve2d) Then
        Exit Sub
    End If
    Dim rangeBox = curve.Evaluator2D.RangeBox
    Dim radius = (rangeBox.MaxPoint.X - rangeBox.MinPoint.X) / 2
    Dim x = curve.CenterPoint.X + radius
    Dim y = curve.CenterPoint.Y + radius
    Dim textPoint = ThisApplication.TransientGeometry.CreatePoint2d(x, y)
    _sheet.DrawingDimensions.GeneralDimensions.AddDiameter(textPoint, intent)
End Sub
    Private Function AreEqual(d1 As Double, d2 As Double)
        Return (Math.Abs(d1 - d2) < 0.000001)
    End Function
    ' Copyright 2021
    ' This code was written by Jelte de Jong, and published on www.hjalte.nl
    ' Permission Is hereby granted, free of charge, to any person obtaining a copy of this
    ' software And associated documentation files (the "Software"), to deal in the Software
    ' without restriction, including without limitation the rights to use, copy, modify, merge,
    ' publish, distribute, sublicense, And/Or sell copies of the Software, And to permit persons
    ' to whom the Software Is furnished to do so, subject to the following conditions:
    ' The above copyright notice And this permission notice shall be included In all copies Or
    ' substantial portions Of the Software.
    ' THE SOFTWARE Is PROVIDED "AS IS", WITHOUT WARRANTY Of ANY KIND, EXPRESS Or IMPLIED,
    ' INCLUDING BUT Not LIMITED To THE WARRANTIES Of MERCHANTABILITY, FITNESS For A PARTICULAR
    ' PURPOSE And NONINFRINGEMENT. In NO Event SHALL THE AUTHORS Or COPYRIGHT HOLDERS BE LIABLE
    ' For ANY CLAIM, DAMAGES Or OTHER LIABILITY, WHETHER In AN ACTION Of CONTRACT, TORT Or
    ' OTHERWISE, ARISING FROM, OUT Of Or In CONNECTION With THE SOFTWARE Or THE USE Or OTHER
    ' DEALINGS In THE SOFTWARE.
End Class
abdullah_elq
The issue is that your code starts a transaction, but never finishes it. Change your Sub main() to the following and the issue should go away.
    Sub main()
        'Start the transaction
        Dim oTransaction As Transaction = ThisApplication.TransactionManager.StartTransaction(_doc, "Generate dimensions")
        CreateIntentList()
        'CreateMarks()
	i += 1
         'End the transaction
         oTransaction.End()
    End Sub
michielXWZ7U
S/O to you my friend ❤️
