Adding a Command to Customize->Ribbon
antunbrnic222
antunbrnic222
According to ChatGPT this code should work but "CustomizationManager" is not recognized
Private Sub AddToCustomization(btnDef As ButtonDefinition)
    ' Get the customization manager.
    Dim customizationMgr As CustomizationManager = g_inventorApplication.CommandManager.CustomizationManager
    ' Show the Customize dialog to allow users to customize the ribbon.
    customizationMgr.EditCustomize()
    ' Note: The EditCustomize() method will open the Customize dialog, allowing users to add the button to any ribbon or toolbar they choose.
    ' Users can drag and drop the button from the "Commands" list to the desired ribbon tab or panel.
End Sub
But only thing i managed to do is this sample that is hardcoded
With this code
"User interface definition"
        ' Sub where the user-interface creation is done.  This is called when
        ' the add-in loaded and also if the user interface is reset.
        Private Sub AddToUserInterface()
            ' This is where you'll add code to add buttons to the ribbon.
            '** Sample to illustrate creating a button on a new panel of the Tools tab of the Part ribbon.
            '' Get the part ribbon.
            Dim partRibbon As Ribbon = g_inventorApplication.UserInterfaceManager.Ribbons.Item("Part")
            '' Get the "Tools" tab.
            Dim toolsTab As RibbonTab = partRibbon.RibbonTabs.Item("id_TabTools")
            '' Create a new panel.
            Dim customPanel As RibbonPanel = toolsTab.RibbonPanels.Add("Sample", "MysSample", AddInClientID)
            '' Add a button.
            customPanel.CommandControls.AddButton(m_sampleButton)
        End Sub
Michael.Navara
Please use standard Inventor API reference and samples instead of ChatGPT.
Here is the link how to customize ribbon in Inventor.
antunbrnic222
Thanks for the reply, I did follow it but this is not what I need, this still hardcodes it to some "TAB".
I want it as a button in Customize->Ribbon so I can later add it where I want it.
kresh.bell
antunbrnic222
I managed to get it to work, the problem was that I didn't specify images for button and that is the reason why i wasn't in customize tab :sad_but_relieved_face:
m_sampleButton = controlDefs.AddButtonDefinition("Sastavnica", "Sastavnica", CommandTypesEnum.kShapeEditCmdType, AddInClientID,,, smallIcon, largeIcon)
smallIcon,largeIcon
