Addin Template
Addin Template
NachoShaw
Advisor Advisor
Addin Template
NachoShaw
Hi
Does anyone have or know where to get a good addin template? I have the InventorNet addin but the update doesn't work at all. I tried installing the previous version but I cant remember the work around for VS 2015
Cheers
Nacho
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
asiteur
Would the following manual be of any help?
aucache.autodesk.com/au2013/sessionsFiles/3375/1476/handout_3375_DV3375 -VBA to Add-In.pdf
Alexander Siteur
Project Engineer at MARIN | NL
LinkedIn
Owner2229
Here is a good template:
autodesk.com/t5/inventor-customization/sample-code-for-inventor-add-in-dll-for-vb-net/
But if you can wait a couple of days, I'm working on something a bit better.
Here is some more useful reading:
autodesk.com/ReadingForLongWinterNights/
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
