AddIn get parameter from assembly constraint object
Jef_E
Jef_E
Hi!
This is probably not so hard to do.. But i'm failing to do it..
I have a tool that creates a certain set of assembly constraints. Now I want to get the parameter that drives the constraint value. But how do you access it?
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
Jef_E
I did some more searching, but could not find a solution.
I was hoping that I would work like the DimensionConstraint but no luck..
DimensionConstraint.Parameter() As Parameter
Why is this not available for AssemblyConstraints?
  • AffectedOccurrenceOne
  • AffectedOccurrenceTwo
  • Application
  • AttributeSets
  • DriveConstraintSettings
  • DriveSettings
  • EntityOne
  • EntityTwo
  • GeometryOne
  • GeometryTwo
  • HealthStatus
  • iMateResult
  • IsDefaultName
  • LayoutConstraint
  • Name
  • OccurrenceOne
  • OccurrenceTwo
  • Parent
  • ResultOfiMate
  • ResultOfLayoutConstraint
  • Suppressed
  • Type
  • Visible
Inventor 2014 SP2
