Announcements
Addin - Forms
NachitoMax
Addin - Forms
NachitoMax
Hey
Whats the general cencus on how forms are managed for an addin? Im having issue getting the right. Originally i declared my form in AddinGlobal as a New form but thats not right as it should be instantiated until needed.
Public MyForm As New MyMainForm
So, i changed it to a declare and instantiated in under the button click
'in AddinGlobal
Public MyForm As MyMainForm
'in button click
AddinGlobal.MyForm = New MyMainForm
But im getting issues as i have sime other forms that get added to my main form that require access to properties and functions of the Mainform. however because it hasnt been instantiated, i get a bunch of errors.
What are other people doing to load forms in their addins?
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
yan.gauthier
You need to separate your model (data structure) from your logic and from your view (your form)
Example (C#) :
public class Model()
    public string property (get; set;)
public class ViewModel()
    public BindingList<Model> myBindingList = new BindingList<Model>();
    myBindingList.add( new Model
        property = "this property",
public partial class View : Form
    public View(BindingList<Model> bindingList)
        // Let say you have set a DataGridView in your Form Designer
        InitializeComponent();
        BindingSource bindingSource = new BindingSource(bindingList, "")
        dataGridView1.DataSource = BindingSource;
In your ViewModel Class, you can subscribe your events and do all your logics. You should place as little code as possible in your forms.
In a way, You should try to setup a MVVM structure you would do in a WPF form.
This way, you never have properties and method in a form.
