AddIn event on document change
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi!
I'm writing an addin that works with iProperties of the active document or the selected document. But I can't find the right event to trigger my code.
What I have now is 2 events,
first when the user selects an item (in assembly) this works fine for me.
' Add event handler for user selected object event m_UserInputEvent = m_inventorApplication.CommandManager.UserInputEvents AddHandler m_UserInputEvent.OnSelect AddressOf OnDocumentChangeEvent
But I want also an event when the user changes document open or switches active document on the bottom with tabs.
' Add event handler for OnDocumentChange event. m_AppEvents = m_inventorApplication.ApplicationEvents AddHandler m_AppEvents.OnActivateDocument, AddressOf OnDocumentChangeEvent
This second event fires more than I like, on open document 2x and on other unwanted moments. What event can I use for this?
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
