- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello, unfortunately it's not possible in Inventor to move planes into a folder if in between parts are located in the model browser. This also happens with patterns and other stuff, see also this idea post by @mcgyvr
As an example (see also the photo), I added "Work Plane1" and "Work Axis1" then I inserted a few parts and also made a pattern. After that I made "Work Plane2" and now I want to make a new folder that includes "Work Plane1", "Work Axis1" and "Work Plane2". But if I select the planes and axis I get the following error:
"Failed to add selected items to the new folder. Accepting will retain the new folder and unmoved items will remain selected. Cancel will undo the "Add to New Folder" command."
If I accept a new folder is created, but without "Work Plane 2". Both planes are made with an offset from an origin plane, so it doesn't have links with other parts/patterns.
Is there a workaround that can give me the desired result?
Inventor 2021.3.1
