I have a 2d sketch defined by a length and width parameter (Rectangle). Within that rectangle I have a cross members (Joists) that are spread evenly across the Rectangle. Picture a deck or platform.
I can update the 2d sketch length and width parameters using simple a iLogic rule and a form and get the joists to add in or delete based on the changes of the span. (rectangular pattern)
I created a frame using frame generator, then update the length and width parameters and the frame members update based on the new inputs except if there are more or less joists they do not get add in or deleted out.
I have scoured this forum and youtube for days and can't seem to find anything that relates to frame generator, patterns and iLogic.
I am using inventor 2021 and am a beginner with iLogic, I can understand what it does, but am struggling to lockdown the syntax and usage.
Thanks for any Help!!
Sean
